DaveT435
Active member
- Jun 23, 2012
- 3,982
Just to let anyone who orders one of these machines know, so you don't make the same mistake I did. I got my polisher today, quickly opened it to check it out. When I pulled it out I heRd something rattle. I turned it side to side, shook it. It sounded like someone had dropped screws in during assembly and just left them in there. Being in the tire business for years I've seen balancing rings, I thought maybe it was something like that. Looked through the manual and didn't see anything on it in the first 5 or 6 pages. I called AG and Tommy was going to send me a new polisher. When I went to repackage it I found a little sticker on the plastic bag that said "Internal balancing system will rattle when shaken" sure enough they used a similar balancing technology. So...the rattle is normal. Actually it's a great technology to use when you have a machine that is designed for two different size plates and pads. As it spins the bearings migrate to the light spot and balance the assembly. The more I think about it the more I like this technology in this polisher, it will allow you to use different manufacturers pads with no negative effect on the smoothness of the machine. Anyone know if the first version of this machine had this feature??
Sorry the pic is sideways...
