Photecs
- Feb 18, 2014
- 127
So, for an AIO for both doing a minor scratch/swirl remover first off... then from that point forward just doing a "polish/buff" to bring back the black glossyness.... which of these products is better and why?
I've been leaning towards the BFTPS as i've seen a couple reviews with good results using a LC White Flat pad. I've also heard that 360 can be a bit of a pain to wash out of the pads after the job is done.
I've got a 1 yr old black metallic car, my DD - just minor swirls/spider webbing. I was thinking of going with either product with white pad (or orange pad if required) to do the correction.. but once it's done, then I want to be able to use this same product every 2-3 months to help remove any lsp before applying another coat of DP Max Wax.
With that said...
1) what product would you recommend?
2) would a white flat pad be okay to apply this product in the future for a quick "buff", or should I be using a black pad if no real correction is required...
3) just to be sure... these products would be okay to use 3-4 times a year without taking away too much CC after 5-6 years... right?
With that said...
