Yellow foam applicators
Tonya
Do you guys wash the cheap yellow foam applicators or just pitch them? If you wash them, how do you wash them? I am guessing just rinse them with the hose and hand wash?
Feed back please
I use them more then once. Sometimes I put them in the washing machine and sometimes I just wash them in pad soap and water then rinse them out. When they get start to get bad I trash them. I basically treat them like my polishing pads.
same here ;)
I wash them with either XMT Cleaner or Dawn Power Disolver, rinse, air dry. Toss when they get discolored around the edges.
:iagree:
Ok thanks! I have been pitching mine. Then realized I don't have anymore ~oops!
I never used to wash them. I usually used them to apply a sealant or wax and then they got demoted to tire duty. When I buy more (need some soon :)) I'll take better care of them as I've heard the more you wash them, the better they get. That was for the Meguiar's Yellow Foam Apps though.
Dunno why anyone would just toss them, they are easily cleaned.
Tossin them would get expensive quick.
I wash then with dish soap and rinse the crap out of them. I did pick up 50 Megs apps off of ebay so I have plenty.
I wash them ..I spray either APC or Power Disolver or Dawn soap and toss them in the wash.,....The Meg's ones are getting harder to find..and the cheapos I have seen are real bad...very thin and flimsy...I use a polishing pal and use 4" pads with it..but the meg's pads also stick to it....so best of both worlds...
AL
Coupe ~ I am only working on my cars, not detailing for others so I don't really use a lot of them.
Budman3 ~ thanks interesting washing might make them better, OK I will find out soon enough.
Wytstang, Al-53 ~ Ok thanks for the information!
I used to use Dawn Power Dissolver on them, and rinse them out really good. Now I am going to clean them in DP pad cleaner, easier to rinse out of pads :). I see the Meguiar's yellow applicator pads in Kragen..
I had problems finding the yellow ones local as well. I recently bought 6 of the red CCS applicators. They rock. It looks like they are made out of 1 piece not 2 glued together. They feel thicker as well. As with the CCS idea, you put the product on the pad and spread it thin when you need more product push harder on the pad and it releases more product. I plan on getting more on my next order. And yes I reuse them.
CCS Red Wax/Sealant Applicator Pads 2 Pack
I use mine until they fall apart. I have the Megs Gold Class ones, probably about 40x new ones lying around. I dedicate one to a certain product and leave them in their plastic baggies. When I need to use them, I dust the residue off and back to duty they go. I've washed them once and it worked OK.
When they're done, I use them to apply tire gel.
