Which is more usefull for general paint correction and some glass polishing? I try to use a rotary when possible but I need some spot buffs in my arsenal.
It will be used with eather M105 or OPII.
I would say orange if you have a softer paint as 105 and op2 will take most of them out with a rotary. Yellow if you have hard paint and need only to remove very deep scratches.
My vote if i could use a rotary would be orange, but I am still learning alot so better wait for the more experienced to give there opinion.
If you are going to use the rotary, go with wool instead of the orange or yellow pads. When using the pc the pcw pad works well. You could also use the orange pad with the pc.
