When do you use the green over the other colors?
Was not planning to go green....but give me a reason and I am there..
As for the yellow, if I am using my PC with one small nasty scratch and using WG TSR, I thought the yellow would provide some help here. I have a red car which is a mess. I do not want to get started only to find that I needed Mr Yellow.
I haven't had to use my yellows yet. My greens though, I use quite often.
Be careful though. There's two greens. Light polishing and heavy polishing. Both come before or after the white pad.
I never tried the light polishing green but the heavy ones cut a little more than white and finish down just as nice
i have the green heavy polishing pad for use with my flex 3401 and it is a very useful pad especially with sip. however it is only available in the 6.5 inch size. i wish that it was available in the 5.5 inch size as i think it would be perfect for my udm and the kbm.
The bottom line is the yellow is (almost) out but the green may be in...
So with TSR and WG glaze...and soon to be 85RD....do I need this green pad? When do I use it with these products...?
Okay...as I was doing some clean-up, I noticed a scratch on the left front panel, which is the basis for the question on the yellow pad. I just used the orange with TSR @ level 6 with PC for a few passes. I got most of this out. You would never see it BUT I DO. My question is will the yellow help me with this one?
With a black car, you see everything (as you know). I do not mind spending $6 for a pad I use everyone once in a while rather than buying either the flex or some other product.
Lastly, I just used the new DP 4-1 in a DP mixture. This stuff cleaned in the inside of my wheels. I am still going to buy some P21S gel, but I am rather impressed with the new DP. Smells nice and is a bit stronger than the original.
:iagree: that is the only time I've used it. Didn't have to stop to clean my pad as often.I use it when I have nasty oxidation to tackle and that is about it.
I decided pass on the yellow pad and thanks everyone for the time and help. I plan to make this work with the orange.
In closing, I used the new big green Cobra 750 MF. I liked this towel for QD and Fuzion removal. Not so much for TSR and WG Glaze but just okay. Also, the WG QD was just as good as Zaino Z8. Did a great job and the green monster performed perfectly. Very happy with the complete WG line.
I just bought the Menz 85rd. Did someone say time to AMP this up a notch. The blue pad is calling me....Yeah, I am addicted and proud of it!
