Yellow stains!
aztec1987
Lately I been washing my family's cars trying to keep them showroom quality or at least clean. Through the times that I clean the car I notice that there are yellow stains in the paint (small little circles). I use a Chenille microfiber mitt to clean my car in which I usually end up removing some of the yellow spots with my nail, do anyone of you use like a plastic spatula (specifically to remove object from paint) or what method you use to remove sticky object from the paint while washing?
Something like this Aztech?
Those are often refered to as "bee poo". A strong stripping soap, claying the paint and a light polish should take care of that (and cleanse the paint of other type of staining)
More like these type of stains but the are usually more bigger. I really don't know where the hell do they come from.
[/URL][/IMG]
[/URL][/IMG]
They do look like bee pollen or "bee poop" and they do dry hard and normally requires a little mechanical decontamination. Looking at the paint, it could use a compounding, so they process described above still applies.
You are in the perfect climate and in the perfect "pollination" season. Let me see if I can find a thread for you where we spoke of those
Thank you! I tend to removed then with my nail since regular mitt cannot remove this without applying pressure!
If you soak them for a while they will start dissolving. Take a microfiber get it nice and wet and if on a horizontal surface just lay it on top of it.
I guess I will pre-treat these stains with some reinseless wash product before soaking the whole car with soap. I usually use a foam cannon and pressure washer to soak up the whole car.
Put a coat of wax on that car. Lsp baby and it should make a buffer between the paint and pollen which makes it easier to remove.
