Yet another duragloss question
drastic_detail
I have put a coat of the 601 105 let it cure than used Aw. my question is, can i put another coat of 105 over the Aw? will it bond to it?
I probably wouldn't try it right away, but AW isn't very durable, so give it a week and apply another coat of the 105 after the next wash if you feel you need it. After the 601 and 105 all you really need is to freshen it with the 951 (AW) every other wash (or every wash if your ocd).
Others with more experience with the product might tell you otherwise though. I have never used the 105, but I used to use AW all the time. I would never put something directly over the AW, I used it more as just a final coat and to freshen the several layers of lsp underneath it.
Aw usually lasts for about a month for me. I am thinking the 105 would remove the AW if you applied it over the top as it has mild cleaning ability. So I don't see an issue with it.
:whs:
Shouldn't be any problem
No problem doing 105 again over the AW....no issues....will work just fine
Al
