What is your process for using a quick detailer? Are you having to use multiple towels (one for an initial wipe and one for a buffing after that?) Are you using more than one (or one set) of towels to wipe down a car? Is there anything specific that you do to ensure that you don't get streaking or spots that look like they haven't been completely wiped off?
(I'm struggling right now with quick detailers...getting alot of 'film' that, in sunlight, is an eyesore worse than swirl marks. What I've been doing is spraying a section with one spray in sort of a sweeping pass...using a microfiber to wipe it/spread it...then flip the microfiber and buff it clean OR use another, dryer towel for same. The result is that 95% of the paint surfaces look perfect while the other 5% look like I didn't wipe the quick detailer off good enough. I think what's happening is that the end of each section I work is having that film look and it gets to be like chasing my tail...wipe over a little bit further and I've got the filmy look at the end of that section...wipe that and I've got more at the end of that. And if I accidentally bump a section I've already done with one of my towels I get the same thing. I'm guessing that the less than 40 degree temperatures are a big part of the cause, but I feel like if I can get 95% looking great I have to be able to get the other 5% if I figure out a method that works. Until it snows I want my cars to look good!
