Your thoughts on 15,000 mile oil changes..
Eldorado2k
What do you guys think? Is it really feasible to think that with modern synthetic oil one could go 15,000 miles between oil changes?
I’ve already decided what my thoughts are on this topic, but I’d like to hear what you guys think. Btw not that it matters, because I don’t use synthetic oil anyways.. But I’m still 1 of those people who changes the oil every 3,000 miles. Always have to maybe it’s just a habit I feel good with.
I totally agree, Ric.
I don't give a rats a$$ what anyone else thinks either.
An oil change costs me around $30.
I'll do mine at about the 3,500 mile mark, or once a year for me.
I am an old school mechanic, and I will not trust that an oil can go 15k. Ever.
And, in the case I am wrong (I am not), what's the harm in changing more frequently??
My thing is that even if synthetic oil can go for 5,8,10,or even 15k miles... When the heck did they invent the oil filters that can protect for 15k miles? Every test I’ve seen online where they cut the filters in half after extended miles beyond 5k they almost always look fubar. Some of these filters like Fram can’t even protect for 3k miles.. Am I wrong?
To be honest, it depends on the manufacturer. In Germany a lot of cars like BMW and Audi are already doing once a year oil changes or roughly 30k miles.
Mazda here started doing that too, moly coated everything in the engine and then uses a high moly synthetic oil. Oil filter is a different category.
End of the day, they're also warranting that so we will see. I know that at the end of the day, doesn't matter. I know a guy who had a 2015 mustang that did an oil change every kilometer. Oddly enough takes it to a brush wash every three days then uses a dry bath towel to dry his car after.
End of the day, whatever you are personally satisfied with.
Fram filters are the absolute worst filters on the market, and it has been proven over a wide spectrum of tests.
And in my experience, (over 33 years of marine/auto mechanics), No.
You are not wrong.
I'll echo the sentiment that for ~$40 every 3K miles, it's worth it for the peace of mind.
Also, I like Krex' graphite oil lubricant. Do not confuse it with additives which can change the oil chemistry.
As for oil filters, NAPA Gold (made by Wix).
I was a territory rep for 30 years. I traded cars at 150k miles and none burned oil. When I switched to minivans I went to 6,000 mile changes and drove the next two to 300k ea then traded. No oil burned. My current minivan is at 250k and no issues or oil burning with 6k changes.
You can’t get more scientific then this! :D
15,000 miles is pushing it, but probably still safe depending on the oil, filter and engine. Newer direct injected gas engines are notorious for oil dilution with fuel, so no way I would take one of those to that kind of mileage. Older engines with intake port fuel injection have no problem going 10k miles between changes with the appropriate oil and filter.
A good friend of mine drives a lot of miles for work (35k/yr) and he has been doing 10k mile oil changes for many years. None of his vehicles have had any engine issues or used any oil by the time he gets rid of them around 150k miles.
Changing oil more often certainly won’t hurt anything, many say it is cheap insurance, but extending the interval won’t hurt anything either if you use the proper oil and filter. I don’t drive that many miles and have multiple vehicles, so I change them each once a year. This usually ends up being around 5k on the highest one and about 1k on the lowest one.
My car gets an annual change with 10 quarts of 5W-50 as I drive it less than 1,000 miles/year.
Doing the change, myself, as I always do still costs me about $170 in material.
When I bought my porsche in 2006, oil change intervals were 20,000 miles and owners protested and porsche changed it to 10,000 miles or yearly. Mine got changed yearly because I never came close to that kind of mileage. Actually, I sold the car with 12,000 miles, 10 years later.
My parent's Toyota gets an oil change by me every 5,000 miles with Mobil1 5W-30
I think there are too many variables to have a blanket rule. What type of driving, what vehicle manufacturer, what type of oil, and even the local climate.
Personally I always like to take check how the oil actually looks, in my previous car, a Holden Berlina 3.0 V6, that's the standard GM V6 from the last 10 - 15 years, the oil always turned opaque and almost black within the first 1000km after the oil change. I also had to top up 1 - 1.5 litres in between changes, and that car had only 50,000km on it. The Toyota FJ Cruiser I have now is the opposite, it has 193,000km on it, but barely changes colour at all, and I never have to add any between changes. The GM V6 always sounded noisier to, they were marketed as Alloytec, but everyone called them Rattletec, lots of vavletrain noise.
Apart from all that, my cars have always come with a used car warranty that requires 6 month services, fixed price, so that's what I've stuck with, even when the warranty ran out. Never had any internal engine issues.
Pic below is after 4 months and 2500km.View attachment 70355
First, when they started using synthetic materials. Second, the problem was never the filter. The limitation was that the oil broke down and then that the detergents wore out. With modern synth oil, the oil does not break down as fast and detergents have improved. The detergents breaking down is about the only issue these days.
3,000 was what oil change places started to tell people. I'll let you wonder why. Here is how often you should change your oil.. open your owners manual and see what the people say who made the engine. There is simply no reason to change it more often unless for some reason you enjoy doing it and wasting some of your money.
You might be able to go 15,000 with full synth and a good filter. Depends on many things such as how long you drive, how aggressive your driving it, etc. Most modern vehicle's take this (and many other things) in consideration and the computer will tell you when you need to change the oil. However, it does not consider that you may be using synth oil.
I'd say the only way to know for sure is with a used oil analysis, but not exceed MFG requirements if you are under warranty.
With my newer vehicles, I go by what the manufacture says.
My 2016 Golf R says 1yr/10K miles. I'll only have about 4k miles on it this year (due to Covid), so it'll get a change in October.
My 2014 Explorer I just follow the oil life monitor (OLM) and change it when it gets down to about 20%, which nets right around 7500-8500 miles. The OLM also takes into account the 1yr/10k mile maximum, so the next year will likely need a change due to time rather than mileage. I've had a few oil analyses completed on the used oil and all say it's still good for a few thousand more miles, so I trust the OLM.
My 89 Mustang and motorcycle get about 3000-4000 miles/year, so I just change them every fall before storage.
15k would be pushing it. When i owned the Xterra i went double the normal drain period. They say double is a good rule. On the ZR2 i go by the OLM. It go's by % left. It also go's by your driving habits etc. I also get the tires rotated every oil change. Tires are not cheap. Dealer uses full synthetic. Runs me about $50 for the service. Rolling computers today is about what they are.
Google up semi truck oil changes. They typically run 25,000 miles. Yes, they hold more oil and do oil testing to support their logic. Some change out filters and run many more miles.
Oh boy, don't get me started... :laughing:
I'm with you Paul. I'm a firm believer in 5,000 mile intervals with synthetic oil, regardless of driving style.
Background: I'm a tech at a BMW/Audi/mini shop, prior to that I was an Audi dealer tech. Been doing this... quite a while. I can tell you from my experience, oil changes are such an inexpensive ounce of prevention.
BMWs have varied on what their "Condition Based Service" calls for for oil change intervals. I've seen them reset to as low as 11k, as high as 24k. I can assure you that these engines do not respond well to going that long. Sludge build up (not just on turbo cars or direct injection) is a big problem, causing problems with variable valve timing components. Cars that followed the factory recommendations also seem more prone to suffering issues with other valvetrain components (variable valve lift). The V8 cars, especially turbos have their valve stem seals lose pliability and end up smoking like Yellow Cabs. Also, when the oil filters stay in past 10k, it's not uncommon for them to "hourglass", or suck down onto the oil filter housing cap (filter insert, not spin on filters). More on this with aftermarket filters below...
Audi's long stuck with 10K oil changes (when they switched to synthetic). I've not seen the same issues with them that BMW has had.
Minis also run 15-20k intervals, and have similar problems as the BMWs. We've had customers tell us when they bought the car at the dealership, the sales people pushed hard that they'd never even need to open the hood between services; ironic because as the cars get out of warranty they're using a quart of oil every 800-1000 miles, only hold less than 5 quarts, and don't have a (low) oil level sensor...
I can only chime in with experience on the BMW filters I see, but I've not seen good results from any parts store filters (especially any made in China or Poland - I'm not knocking the country of production, I'm knocking whoever gave them the standards the parts were made to). These filters are the worst for collapsing, even at "Normal" oil change intervals. I've seen some literally tear through, no longer filtering anything. Also, we see multiple cars a month where the o-rings that came in those kits have gone square and literally pump oil out of the filter cap. And sadly, I looked at a receipt once a customer had - they paid nearly the same amount for that garbage filter as they would have a quality filter from the DEALER.
To me, how you use the car probably has the biggest influence on how long you could get away with for intervals. If you're doing a lot of highway driving, you've gotten the car into it's operating sweet spot and could probably stand to leave it in longer. If you're doing lots of hops/cold starts/lack of full warm ups, then change it more as you're inducing more unburned fuel and moisture from not reaching proper operating temp. You could have the best oil ever designed, but to me I'd still want to get all that not-oil crap out of there.
I would argue against that one (Manufacturer recommending what's best for the engine). As it was explained to me back when I was at a dealer training class (regarding other manufacturers maintenance plans at the time). You have to remember that each oil change counts against the car's total carbon footprint (and maintenance costs). If each car gets one less oil change under warranty, that's (let's say) 7 quarts less of oil that counts against their numbers. Multiplied by however many cars, you can see how much better they look when you trim that out. Keep in mind also that their goal is to get the car through the warranty period. I think of BMW less as "Brought My Wallet" (though it's that too...); I'll play Mike Phillips here and quote myself, since I haven't seen other people using the phrase - it's more like: "Barely Made Warranty". The majority of the repairs we're doing are on cars with 60k-120k. Unless manufacturers have a powertrain warranty past 50k, I find it hard to believe their focus is 200,000 mile longevity. Their focus is power to weight and fuel economy, and however they have to get there. Hence the increasing use of Zero W Thin oils.
This is all just my opinion from what I see with the cars I work on every day. I will happily admit I know nothing about how asian or domestic cars tolerate different oils/filters/intervals. I'm no engineer, so I can't say how the various additives or binders or modifiers in oil come into play at various mileages, I can just tell you - the cars of owners that follow lower intervals have less big issues than those that don't.
I'm replying on my work computer - later I'll try and dig out pictures of the inside of an X3 that was dealer serviced and followed the service light to the letter. Then another picture of a similar year/mileage 335i that did about every 5k with the same oil.
