There are much better interior cleaners out there that are safer and leaves protection behind.Home Depot locally has simple green all purpose cleaner(green) as well as Zep apc (green)
sinple green states it is safe for plastics vinyl etc as well as zep. Which one would be the better choice for interiors at let’s say 10:1 dilution?
Most here are going to steer you away from Simple Green or Zep. Some here use Superclean but again most will steer you away. Not worth saving $20 using cheap stuff if it causes damage to your interior.
You have access to one of the best detail products site in Carzilla.
All purpose cleaners that most AG members would approve that are available at CZ
Bilt Hamber Surfex
Koch Chemie Green Star
Optimum power clean.
All great products geared towards auto detailing.
Of all you mentioned if I HAD to pick one it would be Super Clean. Li would watch a ton of video on it.
Agree with both of these posts.
There is no need to use an APC on an interior................unless you are dealing with mud and grease, and even then, the pH neutral interior cleaners will easily deal with both.
P&S Express and KCx Pol Star are both safe, pH balanced interior cleaners that can be used on all interior surfaces. I wouldn't rules out a rinse-less wash either, I frequently use ONR for this.
I have tried carpro inside at 2:1 and it did a great job in my eyes but again the ph was around 9. for cleaning rubbers and tires will super clean work just as good as p&s undressed or carpro retyre?
that's really odd considering there ads sheet for undressed states the ph value is 9 lol.I can't comment on Superclean, we don't get that in Australia, however, I have used Undressed and Retyre.
I would say ReTyre is the more aggressive of the two, and due to the cost and amount you use per tyre due to the foaming sprayer, I would reserve it for the occasional deep clean.
Undressed is more economical and can do some good work if needed. It doesn't lather as much as Brake Buster when agitated but is still very effective. I feel like Undressed is a little bit of a sleeper.
Undressed sits at about pH 12.0 -
I wouldn't use anything made by Zep or Simple Green on the interior of a car.
Neither would I.
I love Simple Green, and I always have a bottle in my shop, and under my kitchen sink.
A couple of years back, I was using SG to clean up my riding mower before it went to sleep for the winter. I sprayed it all over the deck, frame, and engine block.
As I was wiping it down, I noticed it had stripped some of the paint off of the oil filter. (Paint came off on the shop rag I was using.). No way I'd wipe that stuff on any plastics.
that sounds like a pretty scary sight lol well I guess interior cleaners aren't a cash grab gimmick.... between p&S express interior vs carpro inside which one would be the preferred choice? able to tackle neglected interiors and maintenance interiors.
Haven't used either, but Carpro products are solid. P&S stuff seems "gimmicky" to me.
I have used Griot's interior cleaner and Meg's APC (diluted) as Eldo mentioned above. Both do a great job in my opinion.
P&S Xpress is the real deal. Use neat for heavy cleaning and down to 1:3 for just general maintenance.
For $2.70 more you can get a gallon of Xpress compared to 16oz of Inside.
I like the fact that there a manufacturer too.
I have no problem spending dough on quality products (Kamikaze OC vs 5 cost me $90 for 300ml).
Was not a fan of P&S due to Beadmaker hype.
Most the products I’ve used (Absolute, BrakeBuster, Xpress) were best in class for my usage and will stay in rotation.
Dream Maker was nice for what it is (quick short term amp up in gloss) but decided if I’m going to apply something to entire car would just use something more durable.
