Mike I remember you saying to get 5.5 pads for a PC or GG, do you think these DA's will have enough power to rotate the thin 6.5 pads? or should we just stick with the 5.5 thin pads?
Lake Country and Autogeek product teams, if you are reading this, please note that multi-pad combo packs like you can get for the flat pads are great. Rarely do I even need just one pad, and the combo packs bring down the price per pad a bit.
I need to replace some of my flat pads which are starting to wear out. I might have to pick up a couple to test them out.
Thanks Mike, cant wait to try these. Also a big thanks to AutoGeek and Lake Country for these thin pads, will reduce pad stall significantly and finally an aggressive (grey) foam pad for hard clear coats. Now to bring the extreme grey cutting foam to the Hybrid range so I can use it on my Flex 3401.
FWIW, I was told the GREY LC thin pad works great with Menzerna polishes. Also, HD Adapt.
Will these or the thin meguiars pads work with the backing plate that comes in the meguiars 5 inch microfiber kit?
Quite the opposite the thin pads stall more then thick pads. On contoured edges and curves. That is why griots made that innerflex pad to make the pad thicker to adjust to the curved panel.
The innerflex pad works however at high speeds its junk it shreds.
Thats why i just use LC pads the thick ones for those areas and it spins and rotates fine.
That is on a da of course the flex will have no problem no matter what you stick on it
From the description it looks like these pads are much firmer. It would be nice to have a firm black pad. I almost never use black pads any more because they're so soft that they morph too much when using them and don't finish well. How does the Lake Country Black compare to the Meguiar's Black in terms of density/firmness?
It is my understanding that a thinner hence lighter pad has less energy being lost and will be more likely to maintain rotation. Either way I can't wait to get my grubby lil paws on these and the Buff and Shine Low-Pro's and compare the grey vs green in outright cut. Whichever has more cut, thats the ones I will be reordering on a regular basis.
They are.How are the Rupes and GG long throw polishers not free spinning spindle machines?
are these suitable for the GG Boss g15, or are there better options(other than the ones made by GG)
TIA
I am curious, would these require more frequently cleaning since they are so much thinner?
