FinalTouchAuto
- Jul 5, 2010
- 223
Detailed a 2000 Plymouth Neon yesterday.
This 2000 neon has NEVER been under cover out of the elements, has NEVER seen a coat of wax and hadn't been washed in at least 3 years.
The car was dropped off to me at 10 and I took about 30 minutes worth of pictures before getting into this mess.
I first let the car soak in a low dilution Chemical Guys Wash and Gloss (applied with a foam gun) while I cleaned the tires with Chemical Guys Grime Reaper and an adjustable wheel brush. I dressed the wheels and wheel-wells with Meguiars Hot Shine Gel.
When I was done with the wheels I refoamed the car and began a SERIOUS washing. I scrubbed all over the car (not caring if I made any small scratches because it COULDN'T get worse, so I just tried to clean it the best I could).
I then Clayed the car with Claymagic Blue Clay
Now was the moment of truth to begin polishing. I alternated different spots with Menzerna SIP and Meguiar's 105 depending on the severity of the area. He was only paying for a single-stage polish so I tried to get it to finish off the best I could. When I was done with polishing (1 complete pass over the car took me just over 3 hours) I did an initial wipe-down with Chemical Guys Acrylic Detailer.
I then applied Chemical Guys EZ-Creme Glaze/Acrylic Sealant by PC on a black pad and let it sit for about 45 minutes before removing it.
After it was completely removed I did a final wipedown with Meguiars Ultimate Quick Wax and called it a day, 6 hours later.
No question about it, this car needed wet-sanding and multiple stages of polishing, but the customer got what he wanted to pay for and it came out much better than he was expecting. I was pleased with the results for the work put in.
This is the trunk area...keep this in mind when you see how it finished out
The roof had some severe oxidation that I wasn't able to remove here.
Now on to the detail...
Clean Clay...
After doing 1/2 of the hood...
Done washing and claying...drying for polishing now.
Hood section before:
Hood Section After (Keep in mind he was only paying for a single stage polish, so I couldn't spend all the time needed to completely refine it...it got the majority of the major issues though):
The hood LITERALLY changed colors in front of me it was so oxidized...it was great.
Rear Quarter Panel Before:
After 1 stage polish:
Trunk with direct lighting before:
Trunk after 1 stage polish:
In this next picture both the top and bottom of the door looked the same after washing....guess which portion has been polished at this point (this is my favorite picture I have taken to date, ha ha...my wife loved how drastic it is)
Passenger side 50/50:
Wheels/tires after cleaning and dressing:
I use TW ICE liquid polish to dress plastic trim...I like how easily it applies and how black it makes plastic pieces.
Headlight after wash, clay and PlastX applied via PC and 4" orange pad:
All done :wave:
It was IMPOSSIBLE to finish the roof down at all. It desperately needed wet sanding, but I did what I could. It regained a lot of clarity and removed a lot of major swirls, but you can only do so much with a single pass.
Hood finished up nicely.
Hood again with overhead halogens (each one 300w). This is before I polished the headlight up though.
Thanks for looking. This car was a LOT of work and could still use another 6 hours of labor into it, but the customer was ecstatic with the transformation when he came back after work to pick it up and I was happy to do what I could while staying in the parameters of what I was being paid to do (which is sometimes very difficult when you know it would finish off better with another 2 hours of finishing polish).
Clean Clay...
All done :wave:
