DARK HORSE
Active member
- Sep 14, 2009
- 2,537
Man, between the both of you I'm thinking I need to call out sick for the next few days! My GG polisher/pads/etc.. will be here sometime this afternoon. Of course I work this afternoon so . . . *cough cough* I think I'm coming down with something.
AdrenalineJunky - how long of a process did it take you? Did you split into multiple days?
JonMiles - regarding the IPA, I can understand using it after the M105/205 process (each), but what about after M21 (sealant) before wax? Is it needed or would just a regular MF wipeoff be sufficient?
Good job to the both of you on excellent trucks. My 06 Ram is begging for this treatment. The other forum I'm apart of for my truck is anxious to see the results too!
Do the IPA wipe downs after each of the polishing steps, but do NOT do it after you apply your sealant (IPA will remove sealants and waxes). Follow the directions for the particular sealant you are using. If it is a sealant that requires removal, then do so with a soft MF only. Generally allow 12 hours to cure, then apply wax if so desired.
