good day everyone. today was a really tiring day for me due to alot places to run the whole afternoon and not forget i went to taman muda to help out daniel to restore a persona at the same time, the persona was done very well but too bad i didnt bring my camera along, what a waste.. before i reached back home, a friend of mine who called me to ask me to remove some of the scratches he hit the past few days. tho i was really tired and exhausted but my heart still burning when comes to detailing, instead having dinner with my girlfriend, i ask him to drop by at my place. upon arrival..
hit quite badly as you can see the clear coat and base coat have been peel off
at the same time i also found something..
let me test you if you can spot something in this picture
the answer is..
UH OH! ICQ message receive tone
poop.
the question is..
if you saw a bird poop on the headlamp, what would you do to remove it?
a. scrub it real hard
b. gently remove by power clean
if you are happen to the clear coat would you choose "A" to scrub it? if you choose "B" the result will be? take a look of the pictures i took.
if you have choose "A" this is the result you will get
not clear? take a look of another one
better appearance?
the poop was baked under the sun for quite sometime and the owner went for a wash at the service center they offer (you know how bangras wash the car) you can see clearly the poop was removed but still left the stain and the scrubbing scratches on it. luckily the other poop on the headlamp was safely removed by power clean without leaving any scratches on it. DR. G is so brilliant, he can create a product that is so strong yet so gentle to remove anything on the surface even on the clear coat. after the wet sanding process was done (still not much different) i gave this car a ONR wash, later on seal with Opti-Seal and last step top up with Optimum Car Wax to give more shine a protection.
before
after
not much different but still look better a little
here are the finishing..
before i proceed to last finishing picture i want to tell that ONR is a amazing product have made. 1ounce with 2 gallon of water, imagine you can save so much cost and you can wash anywhere you want, just bring along your ONR and 2 gallon of water and you can start to protect your car in no time. it also creates water tension which will sink down all the dirt underneath. to 1st time user, always remember to use only the top of the solution to clean your car and not forget it can be use as quik detailer too. after wash your car, you can top up with your favorite Optimum Car Wax for greater reflection and protection.
and now you enjoy this
tiring evening but wonderful night, thanks for reading my another story.
Feed back pleaseFeed back please
the answer is..
poop.
the question is..
better appearance?
before
after
