1 of 2 Training Boats for the 2020 Boat Detailing Class
This is a 2012 - 21' Sea Hunt Center Console with severe oxidation.
Here you can see the sides of the hull have severe oxidation and scarring.
In this class you will learn how to,
  • Machine wetsand to remove the deep oxidation.
  • Use Rotary Buffers to remove sanding marks.
  • Use orbital polishers to remove holograms from the rotary step.
  • Chemically strip the gel-coat.
  • Install a ceramic coating.
  • The class will also go over interior detailing.
This is the most comprehensive boat detailing class on Planet Earth and we only teach it once a year and it's coming up fast.
Location: Autogeek's Show Car Garage in Stuart, Florida
Dates: 2-Day Class - Saturday, February 8th and Sunday, February 9th
Price: $950.00
If you sign-up before January 8th, 2020 you get a $100.00 Store Credit at Autogeek.com
We teach the boat class ONCE a year. It's ALWAYS in February. It ALWAYS sells out.
It is the ONLY class like it on Planet Earth.
Here's the dates
Here's the link to sign-up online before it sells out.
Click here to sign-up for the Marine 31 Boat Detailing Class - February 8th & 9th, 2020
Or call Andre and sign-up over the phone.
1-800-869-3011 x1244
If you want to learn how to detail your own boat or if you plan to detail for money, this class is a must!
Learn the ins and outs of boat detailing from world-renowned detailing expert Mike Phillips! The Marine 31 Boat Detailing Class covers all the major aspects of boat care and detailing including
  • Personal safety
  • How to diagnose the four categories of boat condition and how to address each category
  • #1 New and like new
  • #2 Light oxidation
  • #3 Medium oxidation
  • #4 Heavy or severe oxidation
  • How to hand sand and machine sand to remove severe oxidation, staining and deep water spots
  • How to machine polish with orbital polishers to remove holograms after rotary buffer steps.
  • How to seal gel-coats using traditional waxes and sealants
  • How to seal gel-coats with a ceramic coatings
  • How and when to use a one-step cleaner/wax
  • Wet sanding to remove scuff marks and scratches from gel coat
  • Wet sanding to remove "ghosting" left after removing lettering and graphics
  • Outboard engine detailing
  • Trailer detailing - Aluminum polishing
  • How to use the Porter Cable for new and like new boats
  • How to use the Flex 3401 for light oxidation
  • How to use a rotary buffer to remove medium oxidation
  • Personal safety
  • Proper washing techniques and the order of steps
  • Hand and machine scrubbing molded in non-skid surfaces and sealing
  • Machine polishing Isinglass to remove scratches, yellowing and oxidation
  • Top Cap restoration - How and when to use a one-step cleaner/wax
  • Canvas enclosure cleaning and protecting
  • Mildew removal & mildew prevention
  • Metal polishing and protection
  • Electronics detailing
  • Acrylic and Plexiglas windscreen correction and polishing
And much, much more!
The Marine 31 Boat Detailing Class will give you the experience and knowledge to detail boats like a professional!
Boat detailing – where do I start?
Surely you’ve asked yourself that question, or else you wouldn’t be researching and reading about the best boat detailing classes in the first place. We have an answer for that question, and it’s at Autogeek's Boat Detailing Class.
Tools? You like tools?
Our one-day boat detailing class provides an in-depth look at boat detailing inside and out. You'll get thorough instructions on how to properly machine sand a boat, remove sanding marks and oxidation with a high speed rotary polisher, machine-apply a wax using a dual action polisher, and more!
We'll go over how to use the Flex 3401 for production boat detailing.
You'll get to use the RUPES BigFoot 21 for creating a show car finish on black gel-coat boats.
We'll go over machine sanding using the Flex 3401 (that's right we're going to machine sand with the Flex 3401) and the Porter Cable 7424XP Polisher.
For sanding you'll learn how to use the Mirka Abralon Sanding Discs by machine and by hand. You'll also learn why it's smarter to machine sand heavily oxidized gel-coat boats versus compound with a rotary buffer.
Limited Class Size
The class size will be limited to give everyone an opportunity to ask questions and practice the techniques. The class will be held in the fully equipped Autogeek Show Car Garage located at our headquarters in Stuart, Florida.
These are intense hands-on classes!
Carlo using the blue RUPES pad with Captain's Compound to remove holograms...
Here's Lindsey applying ceramic coating to a foam applicator pad...
Here's Mark and Lindsey coating the side of a 28' Rinker...
Applying a ceramic coating to the 21' Trophy - REMEMBER how bad this boat started out?
