105 drying too fast?
Joshs2013MSAltimaSL
So I was playing around with M105 and a wool pad the other day. This was a never before used pad by the way. Now I'm thinking that it was because the pad wasn't primed fully, but the 105 dried way too fast. I would spread it with the machine off, and then go right to correcting. By the time I got to a section, it was dry. This was a 2x2 foot area too. Any ideas on how to get a wool pad primed correctly?
Do not spread it around, that is your main problem. The air from the pad spinning is making it dry to quickly. M105 is suppose to flash quickly, you just need to practice more. I was using it earlier today with a wool pad with no problems.Im the MAN
Are you using a PC? If so, I've found reducing my work area to a tad under 18" square, gives me a decent amount of working time. At least 4 passes.
Also, what size pads are you using?
He has a rotary and is using a Megs wool pad. He just needs to practice more to get it down.
Ah, I see. It definitely has a learning curve. OP, I've heard some members like using a spritz of water to extend the working time. Maybe it's worth a try.
There wasn't any mention on what speed he is using it at either.Try laying down a bead on the part you want to correct and picking up the product that way .
A light (and I mean light) spritz of water on the wool pad helps.
Yeah, I'm using a wool pad and rotary at around 1500 rpm. I was spreading it around and that was my problem. The product was just sitting on the paint until I got to it and dried out. I'm just doing to put some on the pad next time and just start from there. This stuff is such a pain in the butt, but the results that can be achieved by it are worth the time it takes to learn.
Dana, I want to see some pictures of the Lambo!
Work a smaller section because if Tampa is anything like Stewart it's warm and I would even say hot around here.
Clean your pad often. Hate to beat the Pad Washer Drum but I can't say enough about how nice it is to pick up each new bead or strip of product with a clean pad.
Meguiar's recommends misting on some M34 if you want to use a wetting agent but I've used plain water and it works, like AeroCleanse posted, just spray on a little otherwise you'll run into a splatter problem.
Here you go.
Welcome to south fla Mike it's hot and humid all over the place down here.But your lucky fall is here and the temp will drop at least 2 degrees.:xyxthumbs:
This is some tease Dana can't wait to see the finished car pictures.I knew i should of flew up to learn.Looks awesome so far
The only way you will learn the correct way and better than any class you can go to.
Josh - You are more than welcome to come over to my shop in East Tampa and I can give you a few pointers on using M105 first hand.
Let me know if you'd be interested.
