1957 Chevrolet Belair Extreme Makeover - Flex 3401 & Wolfgang Smackdown!
Here's a candidate, a 1957 Chevrolet Belair. This car was painted approximately 10 years ago and while the color is very pretty for this body style, it's filled with swirls and scratches through the entire finish.
When the sun shines on the paint instead of having a deep, wet, high gloss shine, the paint turns all hazy looking. The swirls take your focus off the beautiful body lines the Tr-Fives are famous for and blinds you with ugliness.
You can see these kinds of holograms or rotary buffer swirls throughout each panel when the sun hits them.
The below picture is a good representation of what's called holograms or rotary buffer swirls.
More rotary buffer swirls - Swirls in paint make the paint hazy looking so you never really see the true color.
After wiping the car clean and capturing some shots of the overall condition, we swept out the shop and removed as much dirt and debris as possible and then pulled the 1957 Chevy back in to do a Test Spot.
When doing mobile detail work consider yourself lucky to have any kind of covered shop or shelter to work under and before starting, help to sweep and tidy up a little so you can work clean throughout the paint polishing process.
Now that we've wiped the car clean and moved it back into the shop we're ready to clay all the painted panels. Normally you only need to clay the horizontal panels but after we wiped this car clean we went ahead and felt all the vertical panels as well as the glass, trim and bumpers and everything had a rough or textured feel to it.
The Wolfgang Elastic Poly Clay weighs in at 200 grams and you can easily tear it in half, into thirds and even four pieces of clay and still be able to form a healthy clay patty for claying the paint while saving the rest of the clay for your next detailing session.
In the shot below, we've only clayed the section under the towel and then placed the towel back onto the paint to show you how large of an area we clayed at one time. Then we placed the clay on the towel to get a good picture to show you just how dirty the paint is on the surface. The roof, hood and trunk lid all feel like 40 grit sandpaper.
As we worked around the car we would continually fold and re-knead the clay to expose fresh clay.
Even the thin horizontal panels outlining the windows had above surface bonded contaminants on them as did all the chrome and glass.
The bumpers were painted with a silver metallic paint and then clear coated, they had a rough feel to them also so we misted on some Wolfgang Clay Lubricant and clayed them too, later we'll clean, polish and protect them just like the car's paint.
All the window glass felt rough and textured so all the exterior glass was clayed.
In the shot below I'm claying the chrome trim that surrounds the windshield.
Anytime you can remove any trim, badges emblems it's a good idea to do so, this protects the component and allows you to polish the paint under and surrounding the place where the component was attached.
Old classic cars have a very pronounced rain gutter to channel water off the roof and away from the side windows. The outer, curled up edge of the rain gutter is very thin and it's easy to bump into it with your buffing pad if you're not careful. Usually the paint inside the channel is not 100% smooth and polish and wax residue can become easily stuck into any irregular surface, so when I tape these off I run tape to the outer edge of the rain gutter and then to the paint to seal off the channel.
Next up we're going to tape off any places we don't want spatter, (by accident), or want to protect, for example the fuzzy trim surrounding the window frame that cushions and guides the flat glass. using 3M Painters Tape
Florida weather is hot and muggy!
Be careful and avoid placing tap on any paint that looks like it might lift-off if you were to put tape on it and then remove the tape.
You can even use a piece of tape to make a visual reminder of areas to be careful around.
Compound residue from the other guy....
I always like to tape my plug ends together so they don't pull apart as I'm dragging my cord around. I don't like the method of tying them in a knot as this always gets caught under the tires.
We're ready to do our test spot and for this we're going to use the Wolfgang Total Swirl Remover 3.0 with the LC Hydro-Tech foam polishing pad with the Flex 3401 If this isn't removing the swirls fast enough or effectively enough then will stick with the same product but try the more aggressive LC Hydro-Tech Cutting pad.
Center the pad onto the backing plate...
And then press the pad firmly against the backing plate to fully engage the Velcro.
Continued...
Horizontal surfaces like the hood or the trunk lid always work best for the Test Spot. Here we're using the trunk lid and we've applied a piece of painter's tape to separate between the before and after sides for easier and more accurate evaluation.
Always shake your products well before using them... I like to twist them back in forth at my side...
Lay down a thin strip of product about 6" to 8" long. You'll tend to use less product as you move around the car and your pad becomes more wet with product so it's less likely to absorb product into itself.
Unlike a true Rotary Buffer which the pad would rotate clockwise as you look down on it from behind the buffer, the Flex 3401 rotates counterclockwise and as such we're going to pick up our strip of product running the pad across the panel from left to right and running the strip into the pad at the 4 O'Clock position.
(See the YouTube Video below).
After picking up our bead, we lay the pad flat against the paint and begin making slow, overlapping passes over our test section.
Try to always have a wet film of product at the end of the buffing cycle as buffing to a complete dry buff might lead to hazing if you lose all lubricity on the surface.
YouTube Video Performing A Test Spot using the Flex VRG 3401
[video=youtube_share;3CtUaI_8HhE] - Performing a "Test Spot" to the paint on a 1957 Chevrolet Belair[/video]​
Turning the pad over reveals we're working on a single stage paint job, not a basecoat/clear coat finish. Single stage paints are generally softer and easier to work on than clear coat finishes with the exception of white single stage paints as the pigment type for white paint is Titanium Dioxide Powder and the pigment alone will make the paint, (resin), very unworkable or hard-to-polish.
Next we'll wipe the residue off using a Cobra Indigo Microfiber Polishing Cloth and inspect the results both in the shop and outside in full sun.
This is with the before side being lit up using the flash of the Rebel T1i
This is the after side. The tiny craters or pin holes you see are more than likely what' called Solvent Popping, which occurred when the paint was sprayed. These pin holes are actually present on the before side except because there are so many swirls in the before side, the swirls hide the solvent popping pin holes.
No amount of buffing will remove solvent popping because the holes are throughout the layer of paint, not just on the surface. Compounding and polishing more and more will just remove more paint and reveal a greater depth of the pin holes, it won't make the problem go away.
Keep in mind this is a very high resolution camera and it's being held very close to the paint. After polishing and waxing and then looking at the paint from a normal distance you don't really see them. The only fix is to repaint the entire car or the affected panels.
And a shot right on the tape-line...
Continued...
It's aways a good idea to check your results in at least two kinds of light, so after checking our results with the Swirl Finder Light and the Camera Flash inside the shop, we backed the car out into the sun and inspected our results with full sun directly overhead. At this point this is only the Total Swirl Remover 3.0, no final polishing or jeweling has been performed and there is no paint sealant on the paint.
YouTube Video showing the results from our Test Spot
[video=youtube_share;bBBgveQdndA] - 57ChevyWolfgangTestSpotResults[/video]​
With our Test Spot finished, the car taped-off, we're ready to move the car back into the shop and get busy.
After we saw how well the swirls were coming out using just the polishing pad we tried the same combination on the roof but found a lot deeper scratches, (not swirls), so we switched to the Cyan colored foam cutting pad but stayed with the Total Swirl Remover 2.0 and polished out all the panels with this combination of pad and chemical on the 5.0 speed setting.
The Flex VRG 3401 has PLENTY of power, it's very close to being as powerful as a true rotary buffer without the heat and swirl issues associated with a true rotary buffer. Note the paint will still become very warm so always use good technique and don't overheat the paint in one section when using this tool. Check the temperature with the palm of your hand and as long as your Fight or Flight Reflexes don't kick in and make you jerk your hand away it's probably not too hot.
The Flex 3401 is easier to learn and control than a true rotary buffer but more difficult than a Porter Cable style dual action polisher. The key to keeping the tool easy to use is keeping the pad flat whenever you're working on flat surfaces.
It's important to hold the tool firmly and in such a way as to keep the pad flat at all times. If you tilt the polisher in any direction so as to put more pressure on any of the edges of the pad, the rotating action of the pad will tend to want to walk the polisher in the direction of the rotation of the pad where the pressure is applied. So it's vitally important to hold the pad flat when using this type of tool.
The Brinkman Dual Xenon Flashlight works great for checking your results as your work around the car.
Continued...
After machine cleaning all the paint next up we're going to machine polish the paint only for this step we're going to use the softer Lake Country Hydro-Tech Polishing Pad with the Wolfgang Finishing Glaze on the 4.0 speed setting of the Flex VRG 3401 Polisher.
Conditioning a brand new dry pad with Pinnacle XMT Polishing Pad Conditioner before starting.
Inspecting with the Brinkman Xenon Flashlight
Misting on some Pinnacle XMT Polishing Pad Cleaner
Using the Grit Guard Pad Washer to clean the pad in-between applications of Finishing Glaze. Inside the Grit Guard Universal Pad Washer is one scoop of Wolfgang Polishing Pad Rejuvenator
There's a little Mini Grit Guard type grill that attaches to the top of the pad cleaner and you can run your buffing pad against this and remove a lot of the water that doesn't spin out from centrifugal force.
Much, much cleaner and this will make buffing easier with less gumming up and enable you choice of product to work without being diluted by spent product and removed paint still on the pad.
Working clean is in my opinion, the most important factor next to correct pad and product choice. Technique is very important but if some portion of the process is dirty, then you lose all control over quality of results and product performance, and in this context, product can mean more than just the chemical, it can mean the buffing pad, the wiping cloth, even the tool.
There is no finishing pad in the new LC Hydro-Tech Pad system at the time of this project so we used a Meguiar's W9207 Softbuff Finishing pad on the 3.0 setting to apply the Wolfgang Deep Gloss Paint Sealant 3.0
While the wax was setting up we remove the painters tape and by hand rubbed-out any tape residue lines using a Pinnacle Foam Wax Applicator and the Wolfgang Deep Gloss Paint Sealant 3.0. After that we removed all the paint sealant using Cobra Indigo Microfiber Polishing Cloths and took a few inside shots before pulling the car outside for more after photographs.
The weather turned cloudy so there are no sun-shots but they would have looked better than the results from the Test Spot as at this point the paint has been machine polished and machine sealed.
Frank the owner and everyone else in the shop said the car has never looked this wet and glossy.
I took two videos of the results, one using my iphone, one using the company's Canon Digital Rebel T1i, both came out about the same with the Rebel video looking a little sharper. I've included both of them for your viewing pleasure.
Rebel T1i Video​
[ame=http://www.youtube.com/watch?v=ZHQbvshlw_8]YouTube - 1957 Chevy "After" results from machine cleaning and polishing with Wolfgang Paint Polishing System[/video]​
iphone Video​
[ame=http://www.youtube.com/watch?v=UNH9PQ_9ynU]YouTube - 1957 Chevy "After" results from machine cleaning and polishing with Wolfgang Paint Polishing System[/video]
:xyxthumbs:
Comments
This was the first time I buffed out an entire car using the Flex VRG 3401, the new Lake Country Hydro-Tech Buffing Pads and the Wolfgang Paint Polishing System, so that's a lot of new products to tackle at one time but everything performed as advertised and expected.
Below are a few comments from this experience.
Flex VRG 3401 Forced Rotation Dual Action Polisher
Lots of power, in fact no lack of power for serious correction work just choose and use the right pad and product for the task at hand. The tool is lightweight and this is a plus for any tool especially when doing complete, multi-step buff-outs to large vehicles.
Because of it's power you can tackle a larger section than you would normally tackle when using a PC style DA Polisher but don't go crazy and try to tackle areas like half a hood at one time as it's too hard to focus on UMR if your section are too big. Try to never buff a section wider than the with of your shoulders and usually a little smaller. (UMR = Uniform Material Removal for a Uniform Appearance)
This tool is well made with good fit and finish. I will be tempted to try it without the forward handle next time as the placement of this handle did get in the way when trying to get into complex curves and panel designs. This would mean man-handling the tool a lot more because you would lose leverage over it. So I'll give it a try as I tend to never use handles on Rotary Buffers or DA style Polishers as a personal preference.
The body of the tool around the motor got quite hot, this was expected, not a surprise but some people might not like this characteristic. As long as you keep you hands on the handle up front and the grip in the rear it's not a problem, just an observation I wanted to mention.
I discussed and demonstrated in one of the YouTube videos how holding the pad on edge will cause the polisher to want to walk around, rotary buffers do something similar so no surprise here but did want to point it out as a lot of people may purchase this as their first time entering into machine polishing. Again this isn't so much a problem as an observation as it's a best practice to hold the face of the buffing pad flat to the panel whenever you're buffing out a flat surface.
I used the pad on edge for tight areas and for thin panels, this can be a tad on the risky side so be sure of your purpose first and your grip second and make sure you have plenty of product on the surface for good lubrication. I would not recommend this practice to anyone and instead switch to a tool that offers a smaller pad.
If you're experienced with a rotary buffer you'll figure this tool out in about 60 seconds. If you're new to machine polishing my honest opinion is you'll find learning to machine clean and polish easier with a PC style Dual Action Polisher. Note I didn't say you'll find a PC style Dual Action Polisher BETTER, I typed... easier.
The word better is too subjective for use with online enthusiasts on discussion forums and able to start a Flame War with a handful of hardcore Flex 3401 devotees. :D
The Wolfgang Paint Polishing System is a Bubba-proof multi-step system that is well suited for restoring most daily drivers from neglected condition to excellent condition.
The Total Swirl Remover 3.0 is easily capable of removing medium swirls and scratches while finishing out LSP ready on at least the paints I've used it on so far. It has a long play-time or buffing cycle so it's pretty hard to buff too long with this product and as long as you're making at least 4-6 "Section Passes" on any paint with any tool you're going to have a hard time messing up anything by not buffing long enough, i.e. it's Bubba-Proof.
Wipe-off is also easy and when buffing out large real-estate vehicles like this 1957 Chevy, easy wipe-off is a real blessing a few hours into the project.
Finishing Glaze
The Finishing Glaze does a good job of maximizing the clarity and gloss created by the first step product and also offers a long play time or buffing cycle. Wipe-off is easy as long as you wipe the product off as you go around the car. I let it dry in a few places just a tad to long as I was hustling pretty fast on this project to to get it done in time for some sun shots, (which just didn't happen), and wipe-off became a little more difficult. If you do leave it on too long, a little mist of any spray detailer makes it easy to wipe off.
Application by hand or machine is easy with this paint sealant. I would say again from experience, a DA style polisher like the Porter Cable units, the Meguiar's units or the Griot's Garage Polishers seem to work smoother and thus easier for applying a finishing wax or paint sealant at low OPM's but this tool is certainly capable of being used for applying a wax or paint sealant and as long as you're focusing on the task at hand you can lay down a nice thin coat of this paint sealant which is the goal.
It took me about 20 minutes to remove the 3M Painter's Tape and another 10 to 15 minutes to rub-off any residue lines left by the different products accumulating next to the tape lines. After that I removed the Wolfgang Deep Gloss Paint Sealant and it wiped off very easy with no streaks, smears, or splotchiness.
On a personal note I try not to use spray detailers to remove or even-out the end-results but instead would prefer to wait for 24 hours to allow all the protection ingredients to fully dry and set-up. I'm happy to say on this single stage paint system the results were even, slick and glossy. Wipe-off was a breeze, it took me about 20 minutes to make my first pass all the way around the car using a Cobra Indigo Microfiber Polishing Cloth in each hand with a Rock Star primer. A final wipe using the techniques outlined here,
The Final Wipe
Lake Country Hydro-Tech Foam Cutting and Polishing Pads
Love these pads. (Do I need to type more?)
The Cyan foam cutting pad is very nice because it's not as aggressive as most foam cutting pads but offers more cut than most polishing pads. Use it with the right chemical, tool and technique and it offers a lot of correction ability with the ability to still finish out quite nicely. Besides that, the foam itself appears to be very durable as I used only 2 pads for the entire car with no signs of wear to either pad and that includes a lot of pad cleaning. I believe I could have easily done the job with just one but I'm used to switching pads out more often than I did with this job.
The Tangerine Polishing Pad seems a little more aggressive than the average polishing pad like both the white LC foam formulas and the Meguiar's 8000 series foam pads and this is good and bad. If you're looking for a versatile foam polishing pad with plenty of cleaning power this this is a great pad. If you're looking for a soft, cushy foam polishing pad for light cleaning then this might be just a little too much in the way of density and aggressiveness and you might like a softer pad. This just depend upon what you're trying to do. A good example would be when using a one-step cleaner/wax to restore a neglected finish in one step, this would be a great polishing pad for this application. For applying a finishing wax to a perfect finish I think it's just a tick or two on the aggressive side as compared to a softer polishing foam pad or even a finishing foam pad.
This is very nice new entry to the foam pad market and I would really like to see a finishing pad introduced to complete the Hydro-Tech line. Also a smaller size option in all 3 foam formulas, like 5", maybe 4.5" for use with PC style polishers, especially because there are literally thousands of first generation PC style polishers in the hands of enthusiasts all across the country and segment of the market really needs a smaller pad than 6" due to their lack of torque and power to rotate a pad for correction work.
Large finishing pads just use up a lot of wax and don't work well for thin panels, especially new cars with all their plastic and rubber trim. So a smaller size like 5" might be a strong niche market for this new system with a good matching backing plate for both rotary and DA Polishers.
The above complete system, including the Flex 3401, Wolfgang Paint Polishing System and LC Hydro-Tech Buffing pads, (plus a finishing pad from another line to apply a finishing wax or paint sealant), is a well rounded system-approach capable of tackling a good chunk of swirled-out daily drivers across the country.
A Big Thank You! to Frank at F.M. Custom Trim & Upholstery for allowing us to touch his baby. It was fun working at your shop with you and Derrick and the rest of the crew. On a side note, if you're in the Port St. Lucie, Florida area and looking for some top notch upholstery work I would whole heartedly recommend Frank and his team for high quality, custom work.
I met Frank while looking for someone to make a Bikini Top for my hot rod 1975 Jimmy and after one phone call to Frank I could tell he was the man for the job. Here's a picture of his handiwork and just in time as the rain has been coming down in buckets lately. As I sat in my office processing the photos and videos for this write-up I could look out the window and take comfort knowing my seat was dry.
Oh yeah! Bring on the rain!
:D
:goodpost:no GREAT POSTING:applause::urtheman::goodjob2: NO CORRECTION FANTASTIC JOB!!!!! :thankyousign: :dblthumb2::cheers:
Truly an epic write up and absolutely complete. The Chevy went from a sow's ear to a silk purse in your most capable hands. Thank you for all the hard work only some of which was done on the car itself. The pictures, film clips, opinions, and writing all take time and talent. Thank you Sir....
Incredible job Mike. The writeup was awesome..:dblthumb2:
Mike, how did you polish the smaller sections (roof pillars, etc) with the flex or did you do these by hand.
Remembered reading this part when I saw your post...
Mike - excellent write up. Thank You!
DLB
Mike, thanks it was a truely amazing restoration and very formative. Thanks for all ther pictures it sure is nice to learn from a true professional.
Mike great job on that car. Knowing that your a gearhead, did you happen to get any pictures of what is under the hood?
Great work on the car and write-up. It was well worth the wait. I especially like the videos. Keep em coming.
Great write up. That is quite a bit of paint to correct. Thats not much of a roof on the Jimmy! I though you were from the PNW originally.
