1982 Rolls Silver Spur Barn Find Transformation
Coach Steve
A buddy of mine picked up a 1982 Rolls Royce Silver Spur that had been sitting in a backyard for at least the past 6 years with nothing done to it with regard to maintaining its finish/appearance. It didn't run and was going to cost a bundle to get it running so it just sat. My friend got it super cheap with the intention of cleaning it up, getting it running and flipping it for a profit. Once the wrench jockeys got done with it, he had it towed to his garage and it was my turn.
This thing was rough let me tell ya! It had oxidized to an almost slate gray color. The leather top had split along the seam on the right side. Time and heat had made the material curl and become uber-brittle to the point of breaking off in pieces if you touched it. There were also 2 oil-based stains on the top that I wasn't sure I would be able to remove due to how long they had been there and how deeply they had penetrated the material.
All of the chrome (and there's a freakin' ton of chrome on this bad boy...) had varying amounts of corrosion that had to be addressed with steel wool, by hand. The largest amount and hardest to remove was the corrosion on the wheel covers and the rings. As for the paint, well... you name it, it had it, swirls from Hell, stains, oxidation, scratches, etc. In this particular case, I was glad it wasn't clear coated because that would have added a whole other set of issues.
Rolls Royces are painted with lacquer. LOTS of lacquer! This year/model left the factory with 8 coats of it!
After researching the application method and materials used on the vehicle, I set out on a journey that would either end up being my nemesis or my piece de resistance!
I started by pressure washing the entire car with a fine mist for the most part to get everything off that was going to come off. I followed that with a very long, detailed wash/scrub using all manner of mitts, brushes and mf cloths. At this point I wasn't concerned with marring, scratching, etc., as I didn't have anything in my arsenal that could or would leave any marks in the mess of a finish I was working on. My main goal was to get all the yuck and filth off of it so I had a relatively clean surface to work with.
During the wash process, I was kinda surprised to not see any paint transfer. That came when I clayed it.
I started the claying with the hood using super sudsy water. QDS was out of the question for two reasons: First, this car has an enormous amount of surface area. I would have gone through 3 bottles of it before I was done. Second, I don';t know about you but when you have to pull the trigger on a spray bottle THAT much, my hand gets cramps! It took me about an hour to thoroughly clay the car and I went through 2 bars which were completely black by the time I got done.
Having never worked on a Rolls and not having any kind of reference as to paint hardness, I tested with Meg's UC and a LC yellow pad just to see what kind of transfer I was going to encounter. When I finished my first section pass, I was literally nervous and scared to look at the pad. :laughing: This is what I saw after the first section pass...
I'm not going to narrate each step, I'll let the pics speak for themselves. I followed the basic 3-step process using M105, M205, and Meg's Ult Paste Wax (2 coats). For the chrome, I used Mother's Metal Polish. Glass I used Spray Way after polishing it with M205 and LC orange pad to remove some VERY stubborn water spots!
To address the issues with the top, I first cleaned the entire surface with saddle soap by hand to infuse some moisture and nutrients, specifically lanolin, hoping to rehydrate that nasty crack and make it at least able to be touched and manipulated. It worked. I then cleaned it again with some kind of leather soap my buddy's wife had that she used on her saddles and other horse tack. Incredible stuff! I topped it with Meg's Supreme Shine believe it or not!
As for the interior... It was in unbelievably good shape! The P.I.T.A. part of it was the fact that Rolls doesn't use any vinyl in place of leather anywhere in the car. every door panel, seat back, arm rest, etc., it's real Connelly leather. I used a lot of product, trust me! :laughing:
This ended up being the longest, most dramatic transformation I've ever done. 38+ hrs., endless amounts of product and some very sore arms and back by the time it was all done and over with. It wasn't perfect when I finished by any means but all in all, I was very proud of the results and have since added it to my portfolio.
Here are a couple of pics as a teaser. I really don't feel like copying and pasting all the links in this thread so to see the entire transformation follow the link below to the car's album in my Photobucket gallery. All of the pics were taken with a Canon EOS Rebel DSLR so the pics are hi-res. Be sure to zoom them in to really get the effect.
1982 Rolls Royce Silver Spur Restoration Photos by jrnyman1978 | Photobucket
From just those few photos it really shows just how much work you put into this. Incredible transformation! Keep up the good work!
Thanks! Believe it or not, the second most time consuming, most tedious part was that freakin' Spirit of Ecstasy hood ornament! Grrrrr...!! :laughing:
Sweet! I might line up a job soon with an very old RR. I love them! Great job!!!!!!
My God what a beautiful car. There is just something about Rolls and Bentley that has no equal.
You can see the hard work, and dedication you put into that classic Rolls Royce
Here are some more pics of that beast.
After compounding, before polishing.
Left side compounded, right comp. & polished.
Polished
Still getting some transfer during the polishing stage.
Left compounded Right comp. & polished.
Looking straight down at the hood. The garage door is open above the car. I wanted something relatable in the reflection so I held what I ws drinking at the time out over the hood.
First time I rolled it out of the garage and into the full sun to check my work and search for wax left on.
Easily fit 3 dead bodies and a set of golf clubs in there!
Achieved this shine with Mothers' Metal Polish
One final side note about the car. Apparently, the world was still very much into smoking. This thing had 6 ashtrays with 6 working lighters.... AND IT ONLY SEATS 5!!!! :laughing:
Before and afters
Sent from my SAMSUNG-SGH-I337 using AG Online
Beautiful ride! You could make some dough driving for parades/wedding in that thing. Amazing transformation. How many total hours spent?
Wow, amazing work, probably used 8oz of product just on the hood alone, :P I can't imagine detailing a land yacht like that. Would be fun.
But once again, great work.
Also, totally random, wrong thread buddy.
Before and afters
Your friend has to be TICKLED at how awesome that thing looks!!!! Nice
38+
:laughing: Funny you should say that. As it turns out, it was the first car who's hood I had to do in 8 sections. :eek: Land yacht couldn't be more spot on! There's no doubt about it, that thing is just huge. There are two versions of that car: the Silver Spirit and this one, the Silver Spur. The Spur is the one used for limo conversions.
Wheelbase: 125"
Length: 211"
Width: 74.5"
Height: 59"
Curb weight: 5200 lbs.
6.8L/411 ci. GM engine
The project took the better part of a week since I had to work on it between jobs and when I had time. He was around for the first 3 days, in and out and had to go out of town on business for the next 3 days. The car really came together and started to gain its "wow" factor over the 3 days he was gone so when he got back, I made it a point to be there working on the car when he laid eyes on if the first time in all its glory. His jaw just about hit the ground. :D
Thanks to everyone for the kind words and nice compliments.
The lessons learned from this project and my biggest take-aways are:
1. Vehicles of this quality and stature have superb fit and finish. Every seam, body joint, etc was perfect and equal to its counterpart and the finish was consistent from the center of a panel all the way out to the edge.
2. Lacquer is an awesome finish to work with - especially when it's 8 coats thick! I'm positive I removed at least 1 layer and what was underneath, waiting to shine through polished up and glistened as beautifully as the day it left the factory. Sensational finish!
For those keeping score at home, the invoice on this job would have been $1,940.00 but this was a labor of love for a close friend so I knocked of 50 bucks! :laughing: :laughing: :laughing:
Just kidding. Let's just say he got a SMOKIN' deal!!
Cheers!
PS: For those who jumped down to the end of this thread without scrolling through it, I added a bunch of pics after the fact. So, if you skipped the Photobucket album, a lot of those pics are in this thread. Just scroll back up and check 'em out.
Fantastic job! The pictures truly speak for themselves, and you restored that beauty to its rightful shine and luster. Thanks for posting and sharing it with us.
absolutely incredible. I love seeing the transformation on cars, and especially on old, single stage painted cars. Incredible work.
First and foremost, great work on the car, you really had your work cut out for you and you won! Now onto the car, its really surprising that RR stayed in business during the 80's, the car is borrrrring looking, period! Yeah its hand made and it was made with the best materials available but my God the slab sided styling, zzzzzzzzzzZ! Hubcaps and whitewalls, eeeeek!!
That said, I love the interior, especially the dashboard and the steering wheel. I also like the patina (spelling) of the seats, I would've just treated them with GG leather renjuvinator and let them dry.
The beauty of this car is the hard work put into making it shine like new, now THAT is a thing of beauty:dblthumb2:
Wow, great find; greater restoration!
Sent from my iPhone 5 using Tapatalk
Agreed. The late 70's - thru 80's RR were absolutely anticlimactic in terms of head-turning design... well, at least the full sized sedans were. The coupes and the Corniche were stunning to look at.
As for the leather, now that they have some moisture back in them and they're supple, my buddy is having them dyed today as a matter of fact. The lack of any kind of attention and sitting out in the open in the Arizona sun year after year would have destroyed most other mfrs. leather seats. The fact that they look that good - especially the rear seats and pretty much all the leather besides the front seat bottoms - are a true testament to RR, Connolly Leather of Great Brittan anmd RR's chief hide selector (I swear to God I'm not making that last one up! There is literally guy who's job is to continually travel around and look at cows and assess their hides. :laughing: )
