This will be the first progress update. I worked a little on the roof today. It's pretty banged up compared to the rest of the body.
When I first applied #7 to the truck, the roof got some as well. But today I wetsanded the entire roof:
Note the sanding marks:
Then used some SF 4500 with the grey ccs pad on a few sections, this is a bad pic, but look towards the rear:
This one should be a bit easier to make out:
A closer look, I used a breaker bar to help focus...It was the only thing laying around.
After I finished about 30% of the hood with the SF 4500 (don't have time to finish it all up tonight, gotta run to work
I used the red ccs pad, and went as heavy as I felt was necessary:
Now I intend to let it "soak in" over night, while I'm at work. When I wake up I will remove it. I'm wondering if there will be any change...
The grey pad did get a bit wore out when I was polishing towards the window weatherstipping (which is a bit dry-rotted). When I noticed this was happening, I backed off the weatherstripping. So the area close to the weatherstripping will have to be hand-polished.
Thanks for looking thus far! Hopefully I can get out and do some more this weekend.Im the MAN
