1st Ever Interior Only Post
richy
This is the first time I've ever been asked to only do an interior clean up. The vehicle belongs to a co-worker's daughter who can't afford to have the whole thing done at this time. When you see the pics below, you'll understand why the inside needed doing fist!
The other issue with the interior was there was a smell of cat urine in the back seat. I investigated products to best handle this. I went with a recommendation of Ron from Facebook who highly recommended ValuGuard's Odor Terminator. I was booked weeks ahead and ordered a gallon of this product to deal with the odour.
Here are the before shots:
Method:
For the plastic, I used my AG knock-off pad + OPC at 4:1. All plastic was cleaned.
For the carpeting, I liberally sprayed Folex and then agitated it with my DA brush. I used a white terry towel to remove the worst of the stains and then extracted it using my new Mytee Lite II extractor.
I had called Valu Guard and spoke with a tech guy there who recommended that I extract the seats first, dry them a bit and then spray the Odor Terminator on the seats and let it dwell at least an hour followed by a second application.
Following his advice, I first liberally sprayed Folex and worked it in with the DA brush. I got better stain removal if I used terry towels first to absorb the stains and then extracted. I did so and then used the O.T. It has a strong, but pleasant smell. I was afraid I would smell the cat piss when I was using the extractor, but fortunately I could not smell it. Nor could I smoke a cigar to mask any smell as I was doing interior work. After many hours of drying time following the second application of O.T., the only residual smell was that of the O.T. I don't know for sure whether the cat urine smell will be eliminated or not. I suspect it will be proven by about next June when we get a real scorcher of a day. The product is designed for that type of odour, so I sure hope it did the trick. As far as removing all the stains, see below. The plastic came up nicely too although I forgot to shoot the arm rests on the doors to show the improvement.
Here of course is the ubiquitous disgusting water shot drained from the extractor after the job:
I'm not a big fan of doing interior work, but this was rewarding to get all those nasty stains out and hopefully rid the vehicle of the cat urine smell too. It ended up taking me 4 hours to do the job. Thanks for looking.
Great work as always man! I too Don't like doing interiors.
Nice work Richy, looks really good.
Thanks a lot. I just feel for 4 hours, I could make a lot more noticeable difference to an exterior than an interior, except perhaps this one.
Great work as always Richy.
Thanks so much!
Thanks kindly for commenting!
Bravo! Nice job.
Thanks very much!
Outstanding work SIR:)
Thank you SiR (<--see what I did there with the Si, hehehe). I appreciate you taking the time to comment!
I like interior threads better than paint correction threads, but I am strange in thus regard
Folks, I wanted to update this post using the product that Ron Ketcham suggested.
The true test was whether the smell would re-emerge in hot temps. I checked with the customer and was told that the car is in the southern U.S. and has seen temps in the 90's with NO SMELL!!
Valu Guard Odor Terminator for the win!!
Sent from my iPhone 5 using Tapatalk
Thank you for the follow up, and nice job.
Good to hear it worked well.
Thanks! Since it was the first time using it, I really wanted to know if its long term performance was as good as its short term performance was. To me that was a deal breaker and I was pleased to report its effectiveness.
richy, we all get caught up in the latest thing to make the exterior look its best, but the true, tremendous turn arounds are on the interior.
Great work!!
HUMP
