Meghan
Super Moderator
- Mar 3, 2006
- 15,033
A non-acidic penetrant and lubricant.
1Z Einszett Multi-Oil contains only high quality raw materials that set it apart from other penetrants, which rely on acids to penetrate and loosen. The advantage is a rapid-penetrating oil with advanced lubricant and contact additives that do not harm the metal or surrounds.
1Z Einszett Multi-Oil frees rust, loosens seized screws, nuts and hinges, and eliminates squeaks and creaking. 1Z Einszett Multi-Oil is also used as a contact agent, which displaces water and stops leak currents.
1Z Einszett Multi-Oil dissolves grease, tar and traces of powder. It does not leave an oily residue and is free of resin, acid, and silicone found in off-the-shelf brands. 1Z Einszett Multi-Oil is suitable for use in treating metals and as a gun oil.
10 fl. oz. (300 ml)
