Morning,
Would the new griots 2" backing plate and pads work on the new Flex 3" polisher ????
Thanks !!
No.
Totally different attachment method.
Griot's 2" backing plate uses a 5/16 threaded stud as does the full size Griot's polisher.
The FLEX 3" Mini Polisher uses a slotted backing plate that fits onto a slotted spindle and is then held on with a bolt.
Hope that helps...
I'm sure this is inappropriate based on the forum rules, but if you want create your own 2" 12mm long throw DA the Zentool 3" 12mm DA (Rupe's Mini copy) uses the normal 5/16 threaded stud that the Griot's 2" backing plate will thread into.
I have a Zentool 3" that I purchased as a back up and for my son to use when he helps me. Its not the quality of the Rupe's or Flex, but the power is fine and it has lasted me for about 3 years now. It is a totally functional polisher it gets used all the time.
I have been wanting to purchase the 2" BP and pad kit and additional pads since they announced the new products, but haven't spent the coin yet (waiting on tax return). I am hoping the 2" pads will work okay on the Flex PE-8 with the Flex 2" BP and are not too thin.
I am planning on using the 2" BP on the GG3, but I have been wondering how they will work with the Zentool and the 12mm. Hopefully I'll know within the next month or so.
No, just the Zentool mini. It uses a 5/16” thread like the Griot’s 2” backing plate.So would that mean new flex mini, 75E, and Adams mini can be 2in too?
I've did this on a Adams SK mini with both Griot 2in plate and rotary to danadoer and flex 2in plate.. both had too much vibration for my likingGood deal
Let me know how the 2in works on both the GG3 and the zentool Mini
I tried the 2” on the Adam’s MINI as well and agree about the vibration. The GG3 is actually pretty solid with the 2” backing. Anything larger and it’s pretty worthless, IMO. I reserve it strictly for 2” pads.I've did this on a Adams SK mini with both Griot 2in plate and rotary to danadoer and flex 2in plate.. both had too much vibration for my liking
FWIW, I’m now using the CG hyper flex 3” backing plate with my Adam’s MINI and it really upped the rotation of all pads.
I have not. It would probably work well. Would you use a Flex 1" rotary backing plate and adapter for that?Have you tried a 1 in plate with the GG3?
What are you guys doing for very small backplates and pads?
Right now I am using 5 inch for my normal pads, 3 inch for small areas but I have been wanting to go 2 inch and 1 inch for over a year and have yet to buy something.
First, I think I would like to use a rotary type tool instead of a DA because in such small areas, I don't want to have a 4mm or 8mm throw where it could hit side panels or something.
I was thinking using a drill, but it's not very precise as a polishing tool, there is kind of a torque kick on my drills and when dealling with super small areas, it could make the pad hit something... so I am not too fond on that idea.
I know there are tools from companies like Rupes with very small pads but when i looked at them when they came out I thought they were way too expensive for what they are.
I was thinking maybe some kind of flexible shaft attachement for my drill. Anyone using that?
Open to ideas and would love to know what you are using.
Plus, I think it counter productive using such small pads with a 12mm orbit. 5mm or 8mm would be ideal.I've did this on a Adams SK mini with both Griot 2in plate and rotary to danadoer and flex 2in plate.. both had too much vibration for my liking
Milwaukee (and Sioux has an identical one) makes a variable speed close quarter drill with a paddle handle that you could check out. It's very easy to control.
I like the idea of using the flexible shaft for a modified 1/2-1 inch pad in unaccessible areas. It would work real well with the Milwaukee. I may look into that.
