ScottB
- Mar 3, 2006
- 18,803
- 1
Anthony Orosco said:I use the wax (OCW) because it works great. I have been greatly satisfied with the overall look it gives me.
I have also been happy with the longevity. I get at least 2 to 3 months out of an application. I don't use it in conjunction with any other sealers, polymer or carnauba based. I use it as a stand alone.
Now the area of "longevity" is subjective for who knows if the product is still there? Beading alone can't be the determining factor, nor can slickness. A product may be still on the surface without those factors.....so it comes down to personal preference.
In regards to the PoliSeal. It is a polymer product, not acrylic (by the way, AIO has next to nil in terms of acrylic protection) with an added carnauba. The amount of carnauba added is very slight and only added so it will work with other carnauba based products.
So based on protection PoliSeal would be the better choice over AIO. I also find it less of a hassle to work with and I am finding, as have others, that it seems to clean up trim and such nicely. I don't notice any staining of trim....but this may change as I do more cars with it.
PoliSeal will also correct paint where the AIO is pretty weak, unless doing single stage oxidation removal. PoliSeal is NOT a pure polymer product but rather designed for the car enthusiast that may not have a polisher. What we found though through testing was that it makes on hell of a "one step" for both wholesale and retail detailers...both by hand and machine (rotary also).
If you want something more along the lines of a true polymer, with no carnuaba, then you may want to try my sealant. I will be getting some more beta samples by Friday of the New Year and hopefully the tweaks will fix the issues I was experiencing. If all goes well I'll need some beta testers.
Thanks,
Anthony
I dont know that you actually answered my questions .... Not that thats wrong, but based on your many Optimum posts and clearly working with the designer on product development, I would like a more candid response. I like the polishes and the 4in1 product (god does it stink in smell however) , but find other products in the line to need refinement to move into top 10 positions especially the spray wax.
1. How do you "know" or "feel" that Optimum Spray wax is still working after the first wash. You are correct in that the beading falls off immediately, and slickness is gone also. Infact, I can name numerous QD'ers that actually offer the same feel, look, and appearance and really are not sold as a true spray wax. (we wont get into VOC regulations, and how a spray wax can differ from qd'er versus say a paste wax in relation to solvents so sometimes more is in a name versus bottle). I just dont get the "look" that you describe, it fails to add substantial gloss or reflection, and looks rather mundane IMO. What other subjective/quantatative manners do you use to gauge the product as still working ??
2. You discuss AIO versus Polyseal as I used it in description. We know infact that a acrylic based sealant is traditionally more durable (longer protection not necessarily better protection)than carnauba based products. I would argue that Polyseal and AIO are actually two very different products and I used in error. AIO is a paint cleaner with some protection matching most carnaubas when used alone. It has very little abrasive ability, but use chemical strippers as was based on a Carlack product from the 70's. Werkstatt moves into the same real development but uses newer Carlack product development and polymer technology to increase the look while matching the longevity. (it is not my product of choice, but I would clearly offer Klasse AIO to most as a top10 offering for those that must AIO)
Polyseal really seems to be more akin to Poorboys Polish w/ sealant, or in this case A polish with carnauba. You discuss staining, but I have used AIO successfully in past with no staining. I have also used it as a car soap and washed an entire vehicle with no stains and what appears to be added protection. I have also used the product alone, and seen protection for terms equal to most pure carnaubas (4-6 weeks). So I believe you offered that Polyseal used only enough carnauba to enhance or work with other carnaubas, so it is designed as a polymer hybrid ?? Thats what I was really trying to ask... I really dont personally see the need for another AIO product from any manufacturer. Why move to boutique products that specialize in each area, and then settle for an All-In-One product ?? My second part was more hidden, do you feel if Poly-seal was used alone it would outpace any of the other AIO type products on reasonably nice paint?? (Klasse, Poorboys PWS, Werkstatt, Acrylic Shield amongst others)
4. You suggested above that you dont use any combo's in your work. Does that mean you DONT use poly-seal and then OCW?? Or are you going from Optimum Polish straight to the OCW product ever since this product was developed in your personal work?? The reason I ask, is obviously using the poly-seal under OCW should enhance its durability and likely its look.... so are you using Poly-seal, yes or no ??
3. New question ... you discuss "your" new pure sealant. Is this another product Optimum is bringing to the market ?? Are you the beta tester ?? Are you involved in Optimum in more ways that just using the product ?? Anotherwords, are you bringing your own line to market or just hyping someone elses ?? I know thats a hard question, and not meant to invoke attack, but a question I feel needs answering since you offer the product in reply so often.
Again not challenging the outcome of your work (pics are nice enough) but really want to get into your head as to why you are so pro-Optimum only. Obviously as a professional detailer you want repeat business .... so your going to use the cheapest material in bulk, that looks the best, and offers the best bang for the buck. Why is that Optimum ?? Couldnt you get the same results with Duragloss Aquawax over a common cleaner wax ?? Finishkare 425 over Acrylic Shield ?? Crystal Mist over Poorboys PWS ?? Having tried numerous combo's and products over the years, it catches me off guard since our thoughts differ so drastically on at least one product in particular (OCW) and I truly value your opinion and experience.
