2001 BMW M3 - 2nd Detail
Sa//|XP
This is only my second time with abrasives. See this thread for my first try, with my brother's equipment.
Spent a total of 6 hours yesterday with the following steps:
  1. Wash with Armor All car wash concentrate
  2. Mother's Yellow Clay Bar
  3. Optimum Compound on LC Yellow Pad with Ryobi 4k rpm Random Orbital
  4. Optimum Polish on LC White Pad with Ryobi
  5. Poorboy's EXP Sealant on LC Blue Pad with Ryobi
  6. Natty's Blue Paste Wax applied by hand with microfiber towel
Beginning with the Mother's Yellow clay bar, this clay seemed to do a much better job at stripping contaminants off the paint than the Mequiar's white bar used in my last thread. With the wax removed, swirls became more pronounced in the morning sun...
After one pass with the OC / Yellow LC pad, the swirls were probably 50% diminished, but I was a little disappointed...
I did 2 more passes. I pressed harder on the second pass, allowing the Ryobi to bog down a little bit. The biggest difference was on the third pass, when I drastically slowed down the motion across the paint to probably 1 inch/second.
At this point, all that remained were the deepest scratches, but 90% of the swirls were gone. I'm thinking I could have gone with the Hyper compound, but switching to a PC would probably also help to keep rpm's up when I apply some pressure. Overall, though, I was pleased with the finish that the Ryobi was able to muster, with the yellow cutting pad and OC.
On to the Optimum Polish and white polishing pad, I really didn't expect to see a difference. The OC broke down well and seemed to cut and polish all in one step, leaving behind no apparent hazing. But when I made just one pass with the OP/White, I could clearly see a difference. The front corner of the hood here is polished. You can see the difference between the OCed area on the rest of the hood (diagonal line going from top left to bottom right)...
The EX-P sealant went on super easy with the blue finishing pad. I didn't work it in with the pad, or anything. Just used it to evenly spread it out over the paint. I applied it over the whole car and then buffed with microfiber. At this point, I was beginning to be really impressed. I had high hoped for the Natty's Blue Paste wax.
The wax seemed to add a little more luster to the gloss, but man, I had a heck of a time applying it after nearly five hours of DAing with the Ryobi. I'm thinking maybe an applicator pad would have been easier than the microfiber cloth. I had to soak the cloth with Detailing spray to get any wax on the towel...
Final Result Pics:
That was a lot of work, but one of the most rewarding 6 hours I've put into a car in a long time. Comments and criticism welcome!
definitely much improved...the natty blue goes on really well by "buttering" the lc blue pad and going to town...i can wax my entire care by buttering the pad three times...definitely invest in a pc...the ryobi just doesnt have enough of an orbit and that is why you were probably disappointed in the first pass with the OC...overall much improved...i like the pic showing the use of OP after OC...nice contrast...
wow looks beautiful. i have never seen an m3 in that color. i hate to be anal but i am but in the 2nd pic of the final results i can see some more swirlies/hazing where the sun hits. a pass with OP on a white pad would probably take care of that.
The M-3 is looking great! Is there no cure time with the PB Ex-P Sealant? Natty Blue is great wax, you might give Max Wax a try someday too.
The last shot with the beach in the background is very nice.
Are you serious? I had to swipe the microfiber towel on the Natty's once for every square foot I was working on. Explain this "buttering" process you're using!
I'd like to see how much of an orbit the PC has, because the Ryobi definitely oscillates significantly. I think the main drawback is the small 5A motor. If I apply the recommended 15lbs of pressure, there just doesn't seem to be enough speed.
Yeah, I've been wanting an Imola Red M3 for at least 3 years now. It was my top choice of color, then Orient Blue. There is definitely still some swirling left. I don't know that I'm going to bother with it again with the Ryobi. I'm gonna pick up a PC in a few months and hit the car again with it.
Thanks for the C&C!
Sweet ride the M3 looks awesome.
Well Done.
Dave
PB recommends waiting 30-60 minutes before buffing with a MF cloth. But in hot sun, to remove immediately, one section at a time. It was nearly 80F when I was working, so I just applied it to the whole car (20 minutes, probably), and then went right behind with the MF cloth.
I'm wondering if subsequent coats of EXP will increase shine? When I used Zaino Z2 in the past, it took 2-3 coats of sealant to get an amazing luster.
Wow very nice, now it's looking like a true M3. Very nice color, depth looks really good.
Yea, I noticed some swirls still there but you know what compared to how it was before it looks much much better.
I'm glad that you noticed the difference in claying, how did the clay look when you were all done with it?
Great pictures, the beach one is very nice.
Great job. I love this pic!
How do you like AA car soap? Is it a strong cleaner?
Yeah, it's pretty convenient to have the beach nearby to snap some easy shots that look good. Not as pretty as it used to be, before Katrina.
I continually folded and pulled the Mother's yellow clay bar, so it ended up looking clean when I was done.
It cleans well enough. Main thing I like about it is that there are suds from beginning to end.
