2008 Mercedes 300 paint correction help??
BrianMcLeod
So as the title said I might be doing a paint correction on that car I was wondering if any body has any good combos and if the paint is hard/soft easy or hard to work with?? Thanks
Also what is the difference. Between Wolfgang swirl remover and uber compound?
I just did a 2010 Benz e550, I found the paint to be hard but the Wolfgang Uber did very well for me, I did however use my rotary and a wool pad.
If I were you I'd have some Uber on hand if the paint has a lot of defects.
Don't get caught with not having the right product for the job.
IMO the Wolfgang Swirl Remover may not give you the results you'll be looking for.
Go in it as if the paint is in terrible condition.
Test spot!
Let that be the ultimate guide in what you should use.
Benz paint is typically hard but not to say that it will be so do a test spot and fingers out your combo. Also get a history on if it has been detailed before and lastly find out if it has Ceramiclear on it.
I have a 09 and used m105 and cutting pad then m205 and finishing pad came out really nice...
What is ceramiclear coat? All I have is m 105 and m205 I have different types of pads should I buy more compounds so I can have more options?
Pretty sure 105 and 205 would be sufficient.. Just picked up some 101 better than 105 imo
Sent from my Alien ship
What products do you have that would help?
I have orange, blue, white, red, gold, pads and m105 and m205 what do y'all think? I have black label coating I don't know if I should use that or buy c quarts?
Saying all you have is 105 and 205 is like saying all I have is a 1965 Mustang. Lol
IMO the Meguiar's combo is the best, nothing comes close.
You should not have any problems using the twins.
Good luck:dblthumb2:
Thanks everybody for the help one last question can m105 and m205 go bad over the winter/ summer sitting in the garage?
Not as long as it doesn't freeze, heat doesn't effect it unless it would be left in full sun but not in a garage man.
