SeaJay's
- Aug 2, 2010
- 3,070
Yesterday, I had the pleasure of working on this 2009 BMW E90 M3. Beautiful car and color.
The customer had purchased the vehicle from Texas and there were a few concerns he wanted taken care of. His main concern was some rock chips and the exterior. We agreed upon a 1 step polish and rock chip repair.
Products used:
Duragloss 901
D300 via Megs MF system
Dr. Colorchip system
Meg’s Window Cleaner
Blackfire Total Eclipse Tire Gel
Optimum Spray Wax – used for wheels
Blackfire Wet Diamond
OPC – 3:1
303 Aerospace
ONR – Clay lube
Optimum Metal Polish
UTTG – Trim
Tarminator
Iron-x
Megs Degreaser – 10:1
Pinnacle Ultra Poly Clay
Eraser
Equipment Used:
3 – 5 Gallon Buckets
Chenille Wash mitt
Various Brushes
Various MFs
Ridge Wet/Dry Vac
PC 7424xp
Megs MF Cutting Disk – 2
Pad conditioning brush
Foam Applicator
LC flat blue waxing pad
Cobra Tire Dressing applicator
Ok onto the pictures
Vehicle when I arrived
During my inspection of the vehicle I had noticed several holograms throughout the vehicle.
Tires and wheels were washed first. Wheels were rinsed then sprayed with Iron-x and left to dwell a few minutes before agitating with various wheels brushes. Tires and wheels wells were then sprayed with degreaser and agitated. Then all was rinsed well.
Car was washed via two bucket method using a chenille wash mitt and Duragloss 901.
Once the car was washed it was clayed with Pinnacle Ultra Poly Clay and any tar was removed with tarminator.
After trying out a few different combos for the 1 step (optimum polyseal & Orange LC pad, Menzerna power finish &orange lc pad, D300 & white LC pad), I finally decided upon D300 on the Megs cutting disk. I didn't expect this to finish out as well as it did on the BMW paint.
I was having trouble capturing the swirls on the car and the sun kept playing hide and go seek. So, apologize for not having any 50/50's.
Did get this to come out good though.
After the car was polished , I used eraser to remove any left over oils from the paint before applying BFWD via PC and Blue LC pad.
Trim was dressed with UTTG
Tires got a coat of BF Total Eclipse Tire Gel, and wheels were spray waxed with Optimum.
And the afters
Thanks for reading!
Products used:
Duragloss 901
OPC – 3:1
303 Aerospace
ONR – Clay lube
UTTG – Trim
Tarminator
Iron-x
Eraser
Equipment Used:
Chenille Wash mitt
Various Brushes
Various MFs
Ridge Wet/Dry Vac
PC 7424xp
Foam Applicator
And the afters
Thanks for reading!
