AudiFL
- Nov 26, 2012
- 69
Hello AG!
Here are some pictures of my new one week old Audi Q5. I did a 2 bucket wash with grit guards followed with a clay, polish and seal.
I used following products:
- P21S Bodywork Conditioning Shampoo
- Meguiars Smooth Surface Clay Kit
- Menzerna IS 1500
- Wet Glaze 2.0
- WDGPS3.0
- P21S Gel Wheel Cleaner
Please bear with me since this is my first detail with a DA! I used a GG6 with a 5" backing plate and LC pads. Used the GG3 as well at some spot but I think I will dedicated it for carpet cleaning. As other had mentioned not too much power.
On the downside since the car will be outside 24/7. I had to do everything outside since I didn't have a covered area to work. 4 hours after I coated the car with WDGPS it drizzled and the car got a little bit wet . Based on the coating directions it takes at least 12 hours to cure. Feed back please
My question is Do I have to re-coat the car again with WDGPS in order to get the protection even though the car was at the sun for around 3 hours?
BTW thanks to Andr3wilson for some info on the Menz products. After I did my test spot I ended up using the SIP in order to get rid of the DISOs since the clear coat of that car is hard as a rock!
Here are some pictures of the car.
- Menzerna IS 1500
- Wet Glaze 2.0
- WDGPS3.0
