2014 Black Pearl Honda Accord with Gyeon Mohs+ and Gyeon Phobic
AutoHeed
hi Geeks,
this customer contacted me to get his car detailed and glass coated. the car was 4 months old, but you will see that the defects were so bad due to wrong washing method, DIY polishing, etc.
first time using Gyeon Mohs+ and Gyeon Phobic. easy products to apply and buff. just remember to give enough time to cure (minimum 6 hours) for first layer otherwise the second and third coat will streak and harden and you have to repolish.
the ammo:
ONR
speedy prep clay towel
automiracling compound (a friend made his own compound and i am testing)
CG V38 for final polish
IPA as usual
Gyeon Mohs+ 2 layers
Gyeon Phobic
BFWD to prevent waterspots while the coating harden (as recommended by Gyeon itself to wax after at least 12 hours).
into the pics
if you've made this far, thank you!Feed back pleaseFeed back please
Wow, the after shots look amazing! :xyxthumbs:
Looks like a couple of RIDS still remained - I assume you weren't chasing every single one?
Can't believe there is so much damage on a new vehicles....good job
Wow...4 months and it looked like that?
Great turnaround! Great Pictures as well...good work!
wow this thing turned out awesome!! great job!!! what pad set up and machine did you use?
Top notch work my friend, I've made far to the end, then back to start, and again, ! Awesome, what to say about this, looks like black paint is supposed to look.
Thanks for sharing,
Kind Regards.
I had to Google this Gyeon...never heard of it. I can't find where it is made. Regardless, the pics are a good endorsement for it. It looks great.
Excellent work, and I have to say that's one of the most cleanest most shiniest Honda ive seen
Seriously, that paint looks like black glass! I don't think I've ever seen a black car look THAT shiny.
They're based in Hong Kong and South Korea. Relatively new company - been available in Asia and Australia for 1-2 years.
That Clay Bar was thrashed!
Awesome job! I can shave in that paint's reflection.
thank you everyone for the kind feedback Im the MANIm the MAN
thanks! true, i wasn't correcting every single defect because it was already a huge turnaround and the paint was so soft that I marred it a few times when wiping.
thanks! I used:
- Rupes 15 with Optimum MF Pad for cutting
- Flex Pe 14-2 with LC CCS Constant Pressure Black pad for finishing
- smaller and curvier area with flex pe :)
