2017 Shelby GT350 and the Dr Beasley's NSP Z1
Nspz1 is the beezneez. I used it on my friend’s Subaru that he helped with. He was blown away as well. It is such a wonderful product
Sent from my iPhone using Tapatalk Pro
i used it on a couple panels on a newer camry after running about 6 passes and it was terrible to wipe off-it was like 70 % came of easy and remaining product glued itself
Did you try fewer passes?
I recall two section passes being about it. That’s what I do, and no problems.
That was my experience as well.
Need to review directions....
Tom
When that happens---I'll pick up polisher again and make a couple of more passes then it'll wipe off easier.
Tom
Has anyone come up with an official answer on how much Z1 is appropriate for a single coupe?
Sent from my SM-G960U using Tapatalk
1.5 oz.. does that work?
Every vehicle is different.
It's a very good product but not user friendly.
After your last pass make one quick one over your whole section then wipe off
Thanks...this is good info---will try that the next time I use the Z1...
Tom
Do you get any correction with only two passes? Since it's an AIO, I'd hope you could at least work it a little bit to correct the surface.
Speaking of correction, how good is the cut on NSP Z1?
How did you find wipe-off?
Wipe off was bit hard and sticky at times.
Took the buffer and just did a couple light passes over the sticky polish. Then wipe off became easy.
Twice, gotten hard where buffer trails were still present and I could not remove. Again---took the buffer and did couple light passes--bam, easy wipe off.
After using the Z1 on a few cars and a boat I've found the same thing. Wipe-off can be a bit sticky.
Like you - if I had areas where product was difficult to wipe-off - I just buzzed over the area with the polisher and whatever product was on the pad - this seems to re-liquefy the film on the paint and then I wipe off IMMEDIATELY and no problems.
I called Jim and asked him about this and he said climate can be in influence.
Besides that - what we are experiencing is the nano ceramic coating setting-up or curing. So it's part of the characteristics of a Ceramic AIO.
Jim and his team do read this forum and see our comments. He told me he's working on this formula. Remember - this is brand new chemistry, it will go through an evolution.
I used this product on a truck over the weekend and a boat and in my write-ups for these two projects I'll share one of my techniques for working with Z1
Thanks Mike....
I am glad that it wasn't me....! Thought maybe my technique needed work.
Looking forward the write ups!
Again---Thank You!
Tom
