route66detail
- Jun 30, 2015
- 73
Hello friends. As usual... Thanks immensely that you even clicked on my post.
So we did our 2nd RV today. Camper actually. 2013 26 foot Sunset Trail Reserve camper. Pretty good shape. Customers hot button was the front cap. Was dull and oxidized. I did a test spot up top and the customer happened to walk by to see at that point. Looked great! So I pressed on. Eventually the sections started looking patchy. As if I hadn't wiped the residual product well enough. Well I did. As I went on I started noticing that my results were bad. Yes I brought back the color of the front cap but it was looking dull and patchy AND here and there looking like I could see my section passes.
I learned that when approaching a paint correction that you should use the LEAST agressive approach at first. I started with a one step cleaner wax to see if that would knock it out. I used Pinnacle 360 XMT with a porter cable with white Lake Country pads. Like I said... It looked great when I started out but... My sections started looking different from each other and eventually came out blotchy. Any help you could provide would be great. It did freak me out obviously.
