rolop6
- May 22, 2011
- 230
So, for a while now I had been looking at getting a drill brush for interiors. After looking all over the net for the best and most cost effective brush I found that most were anywhere from $16-$30 PER BRUSH. Thinking there was no way I would pay that much for one brush I came across this video on youtube.
[ame=http://www.youtube.com/watch?v=cKKVQEOTFro&feature=share&list=PLkawBWqZ18JdCLHFfg84vL3V82aittM3k]How to Attach a Scrub Brush to your Drill - Build.com 30 Second Tip - YouTube[/video]
after watching this I immediately went to Walmart and found a brush that would perfect. It even had a pre drilled hole already. I found those dishwashing brushes with a little rubber pump that has a hole where the soap is dispensed. The brush was less than $3 and I had all the hardware. Came home and put it together in about 5 minutes. Ive been using this brush for numerous interiors and it works great. No problems, brush is not too rough and a great value. I highly recommend this to everyone looking to save a few bucks and still getting the product they need. Not to mention the brush I use is very similar to the one in the video and you can get in the little corners much better then you would be able to with a 5" brush. Hope you guys find this helpful.
