3" Mini Polisher- Gen II - Griot's Garage Mini Polisher
3" Mini Polisher- 2nd Generation Griot's Garage Mini Polisher
The new 2nd Generation Griot's Garage 3" Mini Polisher just arrived and I've been waiting for this little puppy to get here so I could take it for a test drive. I'm happy to say that it matches Griot's description of being *New & Improved* with the primary improvement being that it now has more power.
Like its big brother the Griot's Garage Random Orbital Polisher, the new and improved Griot's Garage 3" Mini Polisher , (or 3MP), offers enough power to keep a 3" foam cutting pad rotating under pressure as long as you hold the pad flat and even if you get a little edgy with it.
I loved the "idea" of the first generation 3MP but it just didn't have enough umph to make a top shelf tool, this new Gen II version fixed that problem by increasing the power enough to enable this new version to keep their 3" foam polishing pad rotating under medium pressure on flat surface with no problem.
I did some experimenting with both firm to extreme pressure and on a flat surface it will keep the 3" pad rotating but slower than with just medium pressure but it will keep it rotating. I couldn't stop the pad when working on a flat surface even with a ridiculous amount of pressure.
Here's the point, when working on thin panels to remove swirls you need to keep the pad rotating but you don't want it rotating so fast under pressure that you generate too much heat or you turn the polishing process into a grinding process. In most situations you will be using light to medium pressure and changing your chemical to increase or decrease cutting ability.
It appears to me that Griot's has found the balance between too little and too much and tweaked this new version to work in that sweet spot for good correction ability.
Besides the increase in power there's also
  • 240 Watt Motor
  • 3,500 to 10,000 OPM's - You'll mostly use the 4.6 speed range
  • An improved on/off switch
  • Soft start, constant speed feature
  • An ergonomic built-in grip at the head of the unit
  • 10' heavy duty cord
  • Steel bevel gear drive for smoother operation
  • A standard style backing plate with a 5/16" shaft instead of the previous backing plate that was held on with a Phillips Machine Screw
I'll need to use on some complete buff-outs to get a real-world feel for it before passing final judgment so this is just a primer to share with everyone interested in the new Gen II model.
Without further ado, here's some pictures...
As it comes packaged...
What's in the box...
The top model if Gen I and the bottom model is the new Gen II version
Then new Gen II version uses a normal style backing plate like larger dual action polishers instead of a backing plate held on with a Phillips machine screw.
It includes a set of extra brushes...
Testing rotating ability using some Wolfgang Total Swirl Remover 3.0
On the 6.0 setting working on an A-Pillar
The thin panel surround a window on a Tahoe...
For more information:
Griot's Garage 3 Inch Orange Polishing Foam Pad 3 Pack
Griot's Garage 3 Inch Mini Red Wax Pad
:xyxthumbs:
Is it a large improvement over Gen 1? With the current sale it seems like a nice deal...hmm but what could I use it for to justify buying it hmm..?
In my first post I tried hard to explain that there's a balance between too much power and too little when working with reduced size pads and still being safe, as in no harming the paint during the process.
The first model was lacking in power for effective correction work because it didn't have enough power to keep the pad rotating, this new version does have the power so if that's fits your idea of what the word large means when you say large improvement then yes, it's a large improvement.
One thing for sure, buffing out thin panels is a pain when trying to use a full size DA Polisher or even a rotary buffer, the smaller size of the tool itself with the extra power is definitely to features working for the tool.
Again... I'll have to use it on a couple of "Completes" before I pass any kind of final judgment but from what I've used it for so far it has the power to keep the pad rotating and this will enable it to remove swirls. Afterwards you can slow it down and do any kind of finish polishing or apply a wax or paint sealant if you like.
If the gen. 2 stays running for more than 20 minutes it is an improvement over the first gen. polisher. I tried with 3 different ones and neither of the 3 even worked period. I honestly thought that it was just laughable that a store with such a great reputation and the most excellence in service such as AutoGeek would even handle such a tool. I have a real bad taste in my mouth about Griot's Garage because of this first gen. polisher. I am an optomistic type of person so I intend to follow this thread and others about this second Gen. polisher. I really want a 3 inch polisher in my arsonal of tools but haven't even been able to spread a single coat of wax with any of three first Gen. models:rant:
Hmm good paint Mike on my use of large. Going by some past reviews on Gen 1 the polisher didnt have much power at all, my use of large would be, can this be used to remove paint defects like a regular full size DA on smaller panels such as A-pillars and mirrors. I will look forward to see what you think after you put it through the ringer in future details!
I've been wondering if this would be a good addition to the arsenal.
Did you get your money back?
What a big disappointment for me, to have the old version (Gen 1)and I haven't even used it yet... and now, this better one comes out.
That really sucks!
Especially when it sounds like the old one is a Dog.
I want to clarify something about the customer service at autogeek before I answer this question, Dwayne at autogeek was very attentive to my needs as a customer and in my oppinion had gone way above the call of duty in taking care of this issue for me.
He had even pulled the new one that he sent out of the box, inspected it, gave it a test drive and returned my calls immediately. He has made a life long customer out of me as I was very impressed with the level of service that AG supplies to the customer.:props::props:.
However I was the one who had tired of the returns and waiting for the new polishers to arrive just to find that it is still of the same quality. I just figured to chalk it up as a loss. For $78 it just wasn't worth my time as a very busy person(the height of my detailing season combined with my regular job) so I was the one who dropped the ball as far as getting my money back for this machine. So the answer is no I did'nt get my money back.
I just wanted to clarify that The service was exceptional and that I do not hold AG responsible for this failure. I am not complaining in this thread but giving my oppinion of the first GEN. polisher. The comfort in knowing that there is a place out there to shop at that holds such high standards of customer service was worth the $78 so I don't really see it as a loss at all.
I can comment on this polisher a bit, as my dad is currently on his 4th one.
He has gone through 3 others in the past year. He recently recieved his 4th one, which i had a chance to look at when it came in the mail, about a week or 2 ago. He still had his old one that he hadnt sent back yet, and so I got them both in hand to inspect. You can tell the new one is much more ergonomic IMO. I am anxious to see if this new one will hold up, as I would imagine they redesigned it to deal with alot of the failures associated with the 1st gen.
He had purchased the machine directly from griots, and to their credit, returns on every machine have been effortless every time. In fact, when the 3rd one failed, they actually sent him 2, so he would have a spare if the new one failed again, so he actually has 2 on hand.
I think I will pick one of the new ones up since they are on sale, as I have high hopes that they will outlast the first gen models.
I have never used his, so can not comment on performance, but he absolutely loves it for areas such as doorjambs and pillars.
I have one and use it on the "nooks and crannys" of the Murcielago and absolutely swear by it
Would there be a huge advantage using this instead a PCxp with 3" pads?
To my knowledge, you can only get a 3.5" BP for the PC. It looks like the threads on the Griot's Mini are smaller than the PC's threads.
So if you want to go below 4" pads, it looks like this is the ticket.
DLB
DLB
It says the Gen II Griots mini polisher uses 5/16" thread, so that would be the same as the PC uses.
Also I have seen some 2-7/8" and 2-3/4" backing plates that are available for the Rotary, and if you get the 5/8" to 5/16" threaded adapter you could potentially use these backing plates with the 3" pads on the PC.
It would be nice having the dedicated 3" polisher though so you did not have to switch backing plates back and forth every time you wanted to change between the 3" pads and the larger pads. :xyxthumbs:
I stand corrected. Good catch Mister B on the thread size - I missed it.
Didn't think about using the rotary plate - but that might me nice and give you a little extra reach into those tight spots with the head of the polisher.
I agree though - it would still be nice to have the dedicated small one.
DLB
Mike,
Have you had a chance to use the 3" polisher yet? I'm thinking about getting one but I need a good review first.
Derrick
I just received the Gen II - Griot's Garage Mini Polisher as a christmas gift as well as CCS Spot Buffs 4 Inch Foam Pad Kit Free Bonus!. I gotta love my wife. She wasn't sure of everything she was getting me but she sure did try. I am wondering if the Griot's mini has enough power to use the 4" CCS pads; or should I try and return the kit for some 3" pads? Any help would be greatly appreciated. Thanks
By the words,
enough power
Do you mean spread out a coating of wax? Then yes, it can probably do that.
If you mean remove swirls, which is a nice way of saying remove some good paint off your car, then the answer is no and if it is possible it would be faster with the right tool for the job or remove the swirls by hand with Ultimate Compound.
4" pads are too much real estate to expect the 3" Mimi Polisher to ROTATE under pressure to remove paint. (remove swirls).
