PeteT19640
Member
- Dec 17, 2017
- 517
Hi for my dashboard do I use straight from the bottle undiluted, it's not that dirty?
Thanks in advance
Thanks in advance
No mention of diluting the product:
USAGE DIRECTIONS:
Spray directly on spot until wet. Agitate with a soft brush or wet cloth. Wipe up stain and excess cleaner with a damp cloth, rinsing out cloth in clean water as necessary. Let surface dry. For heavier soils, increase agitation and soak time. Repeat if necessary.
For mildew and special cleaning problems on fabrics, contact the fabric manufacturer.
Will not leave residue on surfaces.
303 MULTI-SURFACE CLEANER IS SAFE TO USE ON A VARIETY OF SURFACES, SUCH AS:
Fabrics: 303 Multi-Surface Cleaner works on all water-safe fabrics and designed to clean even the most delicate fabrics.
Stainless Steel and Chrome: After a family BBQ, let 303 Multi-Surface Cleaner do the heavy lifting to get your grill ready for your next cook-out.
Vinyl, Rubber and Plastics: Use on your spa cover to remove dirt or water marks, perfect before sealing with 303 Aerospace Protectant.
Metal, Aluminum, and Wicker: Take extra care of your patio furniture. 303 Multi-Surface Cleaners unique formula will rinse residue free
It's an RTU product ... Ready To Use as is.
Thanks for your reply.
Do I need to use a damp cloth for a dashboard?
I suggest you read the directions I looked up and posted for you above. The directions say: Agitate with a soft brush or wet cloth.
Good idea spray onto cloth. ThanksIt’s usually best to spray product on a towel first and not directly on the surface. There is always a chance of overspray. You probably don’t want product on your windows or leather seats if you just coated them.
If the surface isn't dirty the just use a light amount on a clean microfiber towel.
Don't over think simple things.
:cheers:
