Klasse Act
- Feb 21, 2012
- 27,705
- 2,735
When treating your rubber seals you used to look for and grab a general protectant and a microfiber towel and figure it out. Usually this meant putting your finger into the microfiber towel and then dispensing the product and wiping it in. This was usually messy and you'd have the product running all over the place, thus wasting it. Then I started using the 303 Rubber Seal Protectant and it made life alot easier doing this important job. Its important to keep these rubber seals protected so they don't get brittle, thus leaving a bad seal letting air and worse yet, over a long period of time of neglect, water into the car. Don't forget about the rubber seals under the hood, those get everything thrown at it, including heat, so its also good to treat those on a regular basis. If you show your car or attend cars and coffee's, these little things add up to make your car look great as well :xyxthumbs:
Its very easy to use as it is dispensed via an old school "shoe polish" dispenser, think about a mini foam applicator at the end of the bottle and when you squeeze on the bottle a bit a small amount of product comes out and you simply get the job done. Don't stop there, coat the outside trim and if applicable, coat the bumper trim as well. Because its 303 you know the protection is great as well as UV protection.
In conclusion, if you've got the itch to treat your rubber molding as well as trim on the outside of the car, give this product a chance and you'll be glad you did :dblthumb2:
