Have you considered M101 seeing as you are familiar with M105.
don't you guys have dusting problems with both? when i use M101 it dusts like crazy its awful you get those little dots all over everything
Guz answered everything accurately and is right about AAT being FASTEST and is aimed at body shop/fresh paint, where HD has longer work times, easier to use, and is more geared towards detailers. All 3 lines of abrasives are body shop safe as well as fresh paint safe.
While the information above is correct, 3D ultra compound and ultra polish are flip-flopped with HD Cut+ and Polish+. 3d ultra compound/polish is FAST and is the lowest priced abrasives 3D international produces and is meant to compete as a competitively priced abrasive geared toward production body shops. The 3D ultra abrasives have a longer work time, less abrasive load, and are heavily lubricated so they tend to preform best on gel coat due to the extra lubricants in the polishes.
HD cut+ and Polish+ are what 3D says is FASTER. I have used every polish and compound 3D international has developed and have gone through AT LEAST 32 ounces of each, including 3D ultra(Fast) and AAT(Fastest). But I can honestly say that the HD line is the best of both worlds and provides both the ease of use and long work times of the 3D ultra line AS WELL as the correction power of the AAT line. I truly believe that if you need a compound heavier than HD Cut+ you would be better off using a compound from a different brand entirely. For me, every polish 3D international makes is incredible. But they just do not have a compound with the cutting ability of compounds like M100, M101, or Menzerna SHC 300.
Hope the helped!!!
3D Ultra=Fast
HD=Faster
AAT=Fastest
I used DP's All In One Headlight Restoring Polish with excellent results.
Depending on the condition, just wet sand with 1500-2000-3000 then polish with DP and an orange pad. Never used MF. From there I've sealed mine up with Blue Magic Headlight Lens Sealer. I usually seal them with various LSP's when I do my cars. Never had issues and results have been great.
Here are some after:
Here's a before of the Honda after a quick clay bar and wipe down to remove gunk.
Not crazy either with the HD stuff just speed and that's it.poxy wasn't some special sealant from mars.used it once and that was it gave it away.really, i tried the hd polish plus and i thought it wasnt great. it didn't finish down as good as m205 when i used them side by side
speeds good huh? i'm in the market for an aio its the only thing i dont have yet. hows the cut on it?
i have some 3d towel clean on the way, we'll see how that is...
I have. My biggest problem is I've read countless things about M100, M101, and M105 and there's nothing consistent about that info. I don't like using something unless I have a good idea about the product.
