3M Paint Defender (Spray-on Clear Bra) Review
af90
I will be updating this as it dries.
3M states it takes 2-4 hours to dry and 1-4 days curing time for it to be water repellent, I believe mine will be done at the minimum if not before as this was done at 90 degrees and the car is parked outside in the sun.
So for this I did a control the driver's side rocker panel was sprayed with the spray film and the passengers side was cleaned and clayed at the same time but left exposed to the elements.
Beginning out here's the kit, I just ordered the spray-can only
It included the spray-can and 1oz of wax to assist in removal.
For the following areas here's the recommendation of cans needed
Leading Edges - 1 can
Full Hood - 2 cans
Front Bumper - 1 can
Mirrors - 1/4 can
Rear Bumper - 1 can
Trunk Lid - 1 can
Rocker Panels - 1 can
You can pick up a kit which includes a microfiber towel and plastic sheeting for $12 but I decided just to go to Home Depot and pick up the sheeting on my own, it was located in the paint section.
Here's what I picked up and it worked quite well.
Much cheaper than the kit.
In total here are all the items I personally used to accomplish this.
A list:
1 bottle with ONR mixed in clay lube/QD solution
2 Microfiber Towels (One for washing, one for buffing the wax)
Clay
Foam Applicator for wax
Plastic Sheeting
Painter's Tape for the sheeting
Knife
Spray Film
Wax
For prep I used ONR and cleaned both panels followed by using ONR as a clay lube.
A bit of dirt on the clay, but not too bad overall, the car was washed a week prior.
Wax:
The wax was extremely easy to apply, but 3M gives you WAY too much, I barely used a 1/4 of the pack and also directs you to not let it dry to a haze, only to apply then buff off. Unfortunately it's not resealable so it was thrown away after use. That was how much product I used and was probably overkill as well.
Now time to tape up the vehicle and sheet it up.
Especially make sure you tape up the creases, near the door, etc…
Here it is sprayed on
30 Minutes After Application
I will update it as it dries after a few hours, and in a couple days once it's cured. That area on the bottom right, is part of an Xpel clear bra and I will be using that to compare the 3M Spray film too as well.
Overall though:
Application was super easy, prep was as easy as it can get, wash, wax, prep, spray. Already though I can see a few high spots but I expect them to level out as it dries. It also is very thin, nowhere close to a plastic clear bra, so for front bumpers it won't handle up to the repeated rock chips, but for lesser traffic areas like mirrors, the roof (specifically front half), rear fenders It's definitely an option, and I think better than taping it up for the drag strip.
Thanks for reading!
I'm interested in this as well
Sent from my DROID RAZR MAXX HD
It lasts a year according to 3M.
Sorry for the confusion, I cleared it up, 3M says it takes 2-4 hours for it to dry and 1-4 days of curing time before it's water repellent.
Dang that's a lot of orange peel, hopefully it goes away like they say..
Subscribed!
I was hoping that somebody would try this before me! Lol!
Thanks for doing this!
I seen another thread about this 3M product on this forum about a week, or two, ago.
I just came from Wal-Mart and noticed that ArmorAll has a similar product for sale for $12 and change.
Have you used Plasti-Dip before? Why should I use this over clear Plasti-Dip with glossifier, or is this basically the same thing?
Forgot to mention...
...that the ArmorAll product comes in three colors, clear, white, and black. Not sure if it's the same type of product as the 3M product or not, but they look similar. With the ArmorAll product you can make some cool racing stripes if that's your fancy. Decide you don't like them, then simply remove them.
It's relabeled Plasti Dip.
I haven't used plasti-dip so I can't compare. But it sounds like it can be trouble to take care of for extended periods of time. I honestly don't know for sure though.
I seen a 4-door Dodge pick-up the other day that looked like the entire paint surface had been sprayed with that bed-liner stuff and then wiped down with something to make it shiny. Gawdiest lookin' thing I've seen for awhile now. However, I bet that truck won't rust...I'm guessing he has also undercoated it well too.
Plasti dip will never lay flat. It will impart its own orange peel.
With this it will lay flat just like a clear bra.
Pd can be laid flat.
Glossifier on top of regular paint will not lay flat, and will give the paint a matte appearence. It doesn't really dry clear. It works good over plasti dip, but not paint. The 3m stuff dries clear and smooth. It's love bug season here in south louisiana, so my next day off I plan on trying to get ahold of the 3m stuff and do the bumper and grille on my f150.
