VISITOR
Active member
- May 10, 2007
- 9,859
- 4
anyone use either (15mm or 21mm) of these yet?
REFINISHING, REDEFINED: The circular and oscillating motion of the 3M Perfect-It Random Orbital Polisher, paired with our matched compound, polish and pads, eliminates the dreaded swirl marks common with traditional rotary tools.
ULTIMATE CONTROL: The tool's variable speed control and a progressive speed trigger let you customize the power you bring to any job.
DESIGNED FOR COMFORT: With multiple gripping positions, its user-friendly design is easy-to-learn and control for technicians of all skill levels.
MANEUVERABLE: The generous 29-foot cord can mean less time spent managing cables.
TWO SIZES AVAILABLE: 3M Perfect-It Random Orbital Polisher PN 34100 has a with 15 mm throw and comes packaged with a 5-inch backup pad. It's also available with a 21 mm throw and a 6-inch pad, PN 34101.
A SYSTEM DESIGNED TO WORK TOGETHER: Part of the easy-to-use 3M Perfect-It Random Orbital Paint Finishing System, which includes pads, liquids, and tools engineered to deliver high-quality finishes. Available SOP (Standard Operating Procedure) process guides deliver step-by-step instruction for common collision-repair paint finishing jobs.
