3M products
eddie6th
Hi,I'm currently using 3M's finishing material with my rotary,wool and foam and I'm very happy with the results that I get.
Has anyone here used 3M Ultrafina? I'm thinking of this after using the above.
I'm a bit limited for products at the moment,but I like the 3M products and is the most easily available to me.
I use it all the time, it's a great finishing product. Check out some of my show and shines and that should convince you of how well it works.
Thanks...i'm glad to hear that,as it's 3M products that are commonly available to me. I've already liked the results with finesse-it.
Okay...I'll be glad to check out your work:xyxthumbs:
I don't use finesse-it, fills way to much. I do use Extra cut and Ultrafina. Ultrafina is now named Ultrafine, comes in a purple bottle with a blue UK top.
Yeah it worked good for what i was doing. Thanks Rocket
Thanks...i'll have a look tomorrow for extra cut also. :xyxthumbs:
I see from your job on the GT500 you used M105/205. It's getting a hold of it is difficult over here. I'm going to try a phone no. for Meg's in italy and see what they can do.
M105/M205 are great products, I use them and then follow up with Ultrafina/Ultrafine.
