WRAPT C5Z06
- Nov 12, 2009
- 12,615
Do they have about the same cut? Does 3M use DAT? Which will finish better?
Thanks, Bobby. Do you know if it can be had over the counter?Mark,
Try to determine the grit 3M Rubbing Compound will remove. I believe Meguiar's M105 will remove 1200 - 1500 grit so this would be a good indicator. I think 3M is about 1200 - 1500 so if this is the case then I'd say yes.
The newest perfect it line or the older perfect it II???3m Rubbing Compound can be found at most NAPAs. If not, they can order it.
:bump2:
It's true about M105. I'm looking for a similar cut compound that doesn't dry as fast as M105.m105 I heard can be hard to work with. 3m compound gives you plenty of work time.
Rocks in a bottle!
I started calling on Body Shops in 1988 and this, or something similar was in just about every shop I called on... It was called Super Duty but I remember a different part number... could be the same...
Back then it was us against them, that is Meguiar's against 3M and now 20 years later 3M owns Meguiar's.
Go figure...
