WRAPT C5Z06
- Nov 12, 2009
- 12,615
Why are they thicker than 5.5" and even 6.5" pads?
I did see the low profile 4" pads, but I don't like the fact they only come in orange. I like to have consistent thickness with each pad size. :xyxthumbs:I know what you mean. I don't like that they're so, so fat! But there is an alternative, have you seen these LC low profile 4" pads? I haven't tried them so I don't know how they feel in use, but if they're made by LC, I think it's a safe bet to believe they're good.
These 3.5" pads look pretty good too.
:dblthumb2:i like the detailers domain 4" "uber" pads. I'm snapping some comparo pics for you right now...
Awesome, thank you!!!Uber polishing pad on left, LC polishing pad on right
They have an entire system of pads, that WORKS, and are VERY durable. More-so than some of LC's models (as far as hook n loop adhesion over the long haul).
The only pad missing in the pics is the yellow cutting pad , and the black waxing pad. There waxing pad and finishing pad are classified in differently.
obviously, further info is located on the back of the pad.
So, as far as cut and finish, would...
Uber Orange = LC Orange
Uber Green = LC White
Uber Blue = LC Black
I think your correct Corey.. are they not cyclo pads?Those look like nice pads Mike
Mark, check out how thick the 4" pads are for the flex 3401 (cyclo/edge pads) Wow
- All pictures are of 4" pads -
They have an entire system of pads, that WORKS, and are VERY durable. More-so than some of LC's models (as far as hook n loop adhesion over the long haul). The only LC series I prefer over everything is the Hydro-tech line.
The only pad missing in the pics is the yellow cutting pad , and the black waxing pad. There waxing pad and finishing pad are classified differently as there is one for each. The Uber pads are manufactured by a well respected company that is used in body shops often.
I like how it tells you on the back which process the colors are for.With all the buffing/polishing pad colors out there (from different manufactures),this is good quick easy reference!
"The Uber Foam Pads now have the step (medium polish/polish/final polish/wax/sealant) stamped on the back of it. "
