Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
5 inch Backing Plates on Meguiar's, Griot's and Porter Cable DA Polishers
Here's some pictures showing the size of different backing plates on the popular Meguiar's Griot's and Porter Cable DA Polishers.
The Griot's and Meguiar's DA Polishers come with 6" backing plates and the Porter Cable by itself does not come with a backing plate.
If you want to use 5.5" foam pads on any of these tools you'll need to remember to order a separate backing plate when your order your polishers.
From left to right...
Factory Griot's 6" BP, Lake Country 5" BP, Meguiar's 5" BP and 5" Black Heavy Duty BP
5" Lake Country held against 6" Griot's Garage Backing Plate for size reference
5" Lake Country Backing Plate on 6" Griot's Backing Plate for size reference
Griot's measures just under 6"
Griot's measures approximately 5 3/4"
Lake Country measures just under 5"
Meguiar's W67DA measures just under 5"
Heavy Duty Black DA Backing plate measures just under 5"
Griot's 6" backing plate too large to safely use with 5.5" foam buffing pads
Backing plate overhangs past foam pad
See the little rubber cap?
It holds the compression washer on the threaded stud and also protects the threads when the backing plate is not in use. Do not loose it and if you do you can simply wrap some tape around the threads while backing plate is in storage.
This is a Compression Washer - Don't lose it and don't use any backing plate without it.
Meguiar's G110v2 comes with the W68DA Backing plate, it's too large to safely use with a 5.5" foam buffing pad.
Meguiar's W67DA Backing plate placed on top of the W68DA Backing plate for size reference
With a 5.5" foam buffing pad attached you can see the overhang of the W68DA Backing Plate
The Meguiar's W68DA Backing plate measures just under 6" in diameter
Griot's Garage 6" Backing Plate, Meguiar's W68DA Backing Plate and Meguiar's W67DA Backing Plate
3 popular DA Polishers ready to rock and roll with 5" backing plates and 5.5" buffing pads...
:xyxthumbs:
:xyxthumbs:
