#845
jgibson2980
I have ordered a bottle of #845 . I am wondering if i should use a sealant with this wax . And if so how long should the sealant cure before i apply the #845?
I am going to apply this on a black truck so i was wondering if the sealant and 845 combo would be extra durable . The truck is new and i am hope no paint correction is needed .
ihaveacamero hit the nail on the head. Apply 845 thinly and your done. Protection will last a long time.
Any wax, paint sealant or coating that works fills to some degree
...You see, any wax or paint sealant that works, that is any wax or paint sealant that leaves itself behind to protect the paint, (and isn't that the purpose of wax or a paint sealant, to leave itself behind?), is going to fill, (at least to some level), because it's coating over and bonding or adhering to the paint.
..."Any wax, paint sealant or coating that works fills to some degree"
...A good thing...
If a wax, paint sealant or even a coating fills to some degree this isn't a bad thing in fact it's a good thing if your goal is to create the nicest looking finish possible. Sure polishing paint to perfection is the goal for many of us and if we accomplish that goal then filling isn't needed. But if the product you use for your LSP does in fact leave itself behind on the surface it's helping to create an even more perfectly smooth surface and in my opinion that's going to help maximize gloss, clarity, depth and shine and that's a good thing...
:xyxthumbs:
Collinite 845 works :dblthumb2:
I have been using Chemical Guys Black light, topped with V7 and then #845 on top of that on some of the black vehicles (and even non-black ones) I have detailed recently and they have come out looking great.
Perhaps it is a case of overkill, because #845 does offer some pretty darn good protection on its own
You can top 845 with any sealant. Is it required? Probably not to the untrained eyes in this world.
If you have some spare cash to burn then go for it. Depending on the sealant chosen it could be anywhere from "immediate" cure time to 8-15 hours. I have Mother's Step 2 sealant and BFWD so I have both cure time intervals covered. ;-)
#845 is a hybrid of sorts. Think of it as a sealant that also contains carnauba wax. Two coats of it (to assure complete coverage) and you are done. Claying prior to applying it makes much more sense than a sealant.
+1
Do 2 coats. I have 2 coats of 845 on my Fusion from September and still beads like crazy with all this crazy NY weather. Have 2 coats of Meg's UPW on Highlander and not holding up as well but the Meg's looked slightly better after same day application.
I used 845 the other day for the first time. I clayed and striped my old sealant, polished with P21S PaintWork Cleanser, applied three coats of 845 (three hour wait between first two coats, overnight for the third). It looks terrific on my "Diamond White" paint! I like spray "toppers" such as AquaWax and Optimum Car Wax but I don't need them. The look of 845 on my paint is just right and the durability will be excellent I am sure. If every so often between full details I think it needs a little "booster" I'll simply apply another coat of 845. It is so easy to apply and buff off that it is almost as easy as a spray wax but looks and protects better.
Of course it's up to an owner to what degree one wishes to spend on a vehicle to protect it?
Most of us are all guilty of just wanting to get a quick coat of protection on a vehicle, due to time, and sometimes cost restraints.
Collinite 845 has no cleaners that I'm aware of, other than the petrol carrier that will dissolve tar, but little else.
After a wash, do a baggie test like Mike P suggests. That will be one indicator as to the condition of paint before applying any wax-sealant.
Vehicles are usually transported by railcar today, and while they have some protective sheeting on them in critical areas enroute, the entire vehicle is not covered, and the paint will pick up contaminants.
My opinion is, the sooner such contaminants such as iron are removed, the better for the paint finish. Better to remove them now if needed, rather than seal them in with any product.
The vehicle, although new, may need products such as CarPro Iron-X, and Claying before proceeding further. Mark
Unless you just want to experiment, I see absolutely no reason to do anything to 845 except add a second coat. For the last few years I've done my winter preps in November with 2 apps of 845. I still had beading in March after a PA winter on a non-garaged DD. This year I did 2 coats of 476 on the same 2 cars and I expect I'd have to chisel the stuff off if I needed to remove it.
Bill
