9 month old corvette
Phil_M
Going to work on a NEW (9 months old) gray corvette next week. Was planning on using either BF One Step or HD Speed, topped with BF SiO2 or Opti-Seal. Am I on the right track, or missing the boat entirely? Suggestions welcome.
Phil
Don’t know about those specific products but look it over carefully. I’ve found all the new ones I’ve done have sanding marks from the factory, and depending on the dealership it came from, the damage caused by an attempted repair.
IMO:
Performing “Test Spot(s)”, with either one
(or both) of the correction products you
listed, will go a long way in determining if
you’re on the right track, or not.
Afterwards:
The BF SiO2 or Opti-Seal will be
the icing on the cake.
Phil
I think this is an awesome way to take care of any car.
KISS = Keep it Simple Simon
I just did this Corvette with Pinnacle Jeweling Wax and people ket asking me,
What ceramic paint coating did you use?
Review: RUPES Mark III BigFoot 21 Polisher by Mike Phillips
And down the road if there were any marring, bird droppings, accidental swirls from washing or wiping I could quick and easy fix by just doing the same thing - using a one-step cleaner/wax.
With a coating it gets a lot more complicated and the average person cannot do it correctly.
Just about anyone with any orbital can use a product like Pinnacle Jeweling Wax, BF One Step or 3D Speed without any skill or talent and get this same result.
Exactly.
I am glad to hear this from you, Mike.
I hope all newbies will take this to heart. Coatings are great for those who are fans of them, but if you're just starting out with paint correction.... Check out this 'Vette.
My point is, all of the info here will naturally gravitate the new guys toward coatings as the newest/greatest thing (which they are to a point).
But, a good old sealant and/or wax can provide incredible results as well.
Just my opinion..........
Yes indeed.
I took your advice and ordered the Pinnacle Jeweling Wax. Should arrive by Thurs.
Will let you know how it turns out.
Thanks again
I have a PC 7424XP and planning on using LC CCS Green Pads
Sound ok. - Looked a car yesterday and could not see any defects - of course it needs a good wash.
I'm just a small guy that does vechicles in spare time - mostly neighborhood clients. Enjoy the heck out of it.
Thank you for the above info. I wanted to add some more info that I think would help you but didn't want to waste your time. I believe you will find the information in the below articles helpful or at least a resources if you should run into any problems.
How to correctly use an AIO or Cleaner/Wax by Mike Phillips
Good rule of thumb when using an AIO - stick with foam polishing pads by Mike Phillips
The Definition of a Section Pass by Mike Phillips
Tons of info here and a great video that is clear and precise on how to use the Porter Cable.
Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
And last but not least
Lots of pads
You also need lots of pads. Just like using a compound to correct a car's paint, when using a one-step cleaner/wax you need a lot of buffing pads. When using a product heavy or wet the pads are going to become wet or soggy fairly quickly. When a foam pads become wet it becomes USELESS. This means you're wasting time and in most cases destroying the pad as a wet pad hold in heat more than a dry pad. It will also take you longer to buff out a car because the pad is no longer doing correction work. And to top it off, your results won't look as good than had you switched to a clean dry pad often.
I recently used a jeweling wax, (like a cleaner/wax only finished out better and more consistently on a wide spectrum of paint types), and look how many pads I used to do the job a fast as humanly possible while working safely and maintaining pro results.
As you work around a car your pad gets soggy and wet from repeated applications of the products you're using. Wet pads don't work well. Cutting pads quit cutting. Polishing pads quit cleaning.
