A couple questions...
F150nCA
Yesterday i washed, clay bared and waxed my truck.
I used the meguiars clay bar and the 'cleaner wax liquid'
Everything turned out great but my question is do i need to polish the truck also or is the wax sufficient?
Its a dark blue f150 and i saw the 'deep crystal polish' so i stared to think i should use this to give it the final touch.
I read through the "how to's" and didn't really get an answer.
Thanks for your time!
You should be fine with the cleaner wax for now. The megs polish is more of a glaze than an abrasive polish. If you don't have swirls you are fine. If you do, you can start with some SwirlX and if that doesn't take care of it, some Ultimate compound. These can both be bought at your local walmart or autozone. You can top it with some NXT Tech wax or the new Gold Class wax. Most would tell you to stay away from the turtle wax products..
Hope this helps and gets you started.
Jenn
