A Shiny Red G8 GT... showing the benefits of a one step correction on a daily driver.
I don't get to try many interior products since I don't do much interior work so I always keep 303 on hand since I happen to like it.
In my eyes you're one of the best in the business my friend:)
I always read up on your work.
On the Optimum Hyper......
I'm surprised it worked that good for you, I had no idea it corrected so well.
Thanks for posting your amazing work.
Kevin
Kevin
Thank you very much for the kind words, Kevin!
Regarding OHP, if you have seen the Autopia Polish Comparison Chart, Optimum Hyper Spray Polish is a solid medium polish with a cut rated at 5 out of 10 on this scale, but also finishes down quite nicely on "non-finicky" paints.
By using it with a foam light cutting pad, I was able to achieve great cut for a one-step and since the GM paint is typically quite nice to work with, I was able to finish down perfectly as well.
I typically would've used M205 for something like this, but I had recently received the OHP and wanted to try it out. I was very pleased with the results on this vehicle.
This might be a stupid question but I am going to ask it anyway lol. I see that you washed and decontaminated the car, then put it away for the night and polished it the next day. My question is did you do anything to the car the next morning to get dust or anything like that off the car that might have built up that night?
Typically there is minimal dust on the surface the next morning. If there is some build up, my first step is to take my master blaster and blow it off. If that does not work well, I will do a quick waterless wash with some ONR.
