Ac treatment
emunoz1979
How much would you charge for ac treatment? Please help!
Sent from my SM-N900T using AG Online
I use the 1Z einszett Klima-Cleaner - A/C Odor + Bacteria Cleaner. I charge $30 so it covers the cost and and I make $15 for doing nothing really.
I got two cans of this-one for my 2011 Silverado and one for my wife's 2005 Accord. I sprayed it in the vent (I forgot which side, but whatever the directions said to do). In both instances, a pretty decent amount of it dripped out from under the center of the dash. Have you seen this before or is it normal?
Thanks everyone, managing a detail shop in houston, tx..just don't want to over charge, or loose $$, using the bombs..is this good??
Something other detailers will do is call around to the competition and ask them what they are charging for this type of service.
This will give you a good idea for what the price is in your geographical location.
I'm curious where all the solution goes and the effect it may have once puddled up on the plastic vent work inside the system. Does it stain carpeting if it leaks out?
The bomb I use, goes thru cycling mode in ac, there is no mess, actually works pretty good, just want to know is there a better treatment.
Thanks mike, is there others you would use that is better than the bomb!
