Do you spritz on the paint?
It can be a little too much of product that way sometimes. Spritz in the mf towel and spread it out and then remove it can be easier to buff it off. And this way you don't need to be spritzing the mf towel every time you spread it out as you get it more saturated as you go. On an already protected paint 1-2 sprays per panel is what only is needed. As this is very concentrated stuff it's goes a long way.
Humidity plays a big part with SiO2 heavy products. With a high humidity environment you apply it in can be a trouble with the application. As they can dry faster initially and then take a little longer to cure fully. So even a dew can effect the applications. Or if you have washed in the garage and even outside in hot temperature you have the water that evaporates around the car. This is extreme cases though and not so common.
And to get it too even more extreme. If your paint is very flat and compounded and polished to get there and even wet sanded for that flat reflective paint we like. Then when you use a coating it's flatten the surface even more. And more so if more layers is done. I think that these kind of paints can not accept more protection on it but very little. And the product leftover has to go somewhere. That's back into the wipe off mf towel. Remember that this is on a very small level and not visible to the eyes. I don't know but just think this as experienced when used these kind of stout protection products very often. And the more streaking galour I got after every application. Then the finish got kind of hazy look. Don't know if it's the same for you. There are so many variables it can be.
How old is your bottle of Cosmic Spritz?
