Advantage applying wax with DA?
Wax >$100 = Hand application
Wax <$100 = Machine Application
I like to get up close and personal, take my time with the nicer waxes and enjoy it. I like LC Red Euro Hand Applicator. I just quickly "throw on" a coat of the less expensive ones via Flex 3401 & LC Blue/Red.
if you like the red CCS, these pads are amazing !!! They will fit into most wax jars as well.
Lake Country Beveled Edge 3.5 Inch Pad Pack
I know the picture shows flat pads, but CCS pads are actually shipped with the order. I was very impressed with them and I normally dont use CCS pads on a machine, but I found the CCS to be very effective using the pad for a paint cleaner or a wax. When i applied a tad of pressure, I was able to get more product to work. If you want a pic of the actual pads lmk, i will post one.
You will need the polishing Pal as well to go along with them.
Pinnacle Polishin’ Pal
and here is the combo of the pads and hand polisher. and you will even get some free orange pads that can fit your machine polisher spot backing plate.
Pinnacle Polishin’ Pal is an ergonomically shaped urethane handle that holds specially designed foam pads using tough hook & loop backing.
i got a polishing pal, i'll do large pannels with my DA/red crimson finishing pad and some tight pannels with polishing pal/red pad
now, wich LSP to use? i got a free jar of fuzion and bought 100% p21s. I'll put polycoat under the wax.
