Advice from CG blacklight users?
kjk66ss
Hey everyone, getting ready to detail my truck.
Wash
Dry
Clay
Polish
Now I have the black light and V7 kit.
I will be using WGDGPS 3.0 as my sealant and will too it with some dodo juice light.
Question is where can I fit in the blacklight and V7 on this detail?
WGDGPS would work best applied to the bare paint, so would Blacklight. However, I'd rather the WGDGPS prolong over the Blacklight so I would do:
WGDGPS
Blacklight
Dodo
V7
I think I might just save the v7 as a QD for just routine washes. It makes more sense to apply the WGDGPS to the bare paint. I haven't really figured out when I a good time to use the black light would be.
If you're topping BL over WGDGPS, make sure hand application only.
Blacklight contains mild abrasives...
+1
Bl is a glaze I would use this before wgdgps and then use dodo light after the sealant cured. V7 to enhance gloss and add additional sealant
Sent from my SCH-I605 using AG Online
+1
+1
Acording to multiple sources at Chemical Guys themselves... Black Light has ZERO abrasives. In one of the replies I received it was described as EZ Creme Glazed combined with JetSeal 109.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Black light is like a sealant glaze, you can try topping BL with dodo juice and maintain this with V7. Try letting BL cure more than its recommended curing time before topping it. Or forget about BL, just use wgdgps instead then top this with dodo juice, maintain with V7.
That's cool. Never talked to the guys at Chemical guys about Blacklight. The general forum consensus being it contains abrasives. :props:
Also, just rewatched one of their videos on blacklight. They stated you can use it on top of a sealant.
For me, I'll still continue to apply before sealant.
I use black light after any correction on clean paint. I can't honestly say it does anything for the look of the car (in my oppinon) but I use it more so because its a sealant. After that I top with a nuba for none DD vehicles.
Directly from the Chemical Guys website:
"Black Light contains very fine abrasives in the formula to help clean and lightly polish the surface while it’s adding gloss and protection."
Yeah... I know... That's Cooperider's review or endorsement or whatever it is.. I just know after two contacts with CG themselves they claim no abrasives. Why would they publish a review stating it does if it in fact does not...? Who knows. Do I know for sure... Nope. I do like the stuff though.
Great point Josh!
Maybe those guys need to re-read their writeup and vote on it! :laughing:
I like BlackLight a lot. It's so easy to use and gives outstanding results.....:props:
Great point Josh!
Agreed. I for one am a CG fan. I like a lot of their products - both from a performance and economical standpoint. That said, I believe their marketing, labeling and somewhat "Outta this world" claims do hurt them somewhat with established detailers. I know there are product snobs out there and those who are loyal to one or two particular brands, and that's just fine... But CG does have some good products if you can just cut through the inconsistencies such as Black Light.
