What machine do you have?I need to buy a set of 6.5" pads.
Are the new LC Hydrotech pads a good 'substitute' for the CCS orange+white+black combo?
I'll be using them with the Menzerna P203s and PO85rd on Honda paint.
Thanks.
Raoul
If you have the older pc, then I would go with a 5.5" pad and get some 4" pads for heavier and tighter correction. The older pc doesn't have the power to spin 6.5" pads.Hi there.
I have a PC.
It's not so much the pad as it's the size. The new XP, Flex and new Griot should not have any problems spinning these 6.5" pads because of the increased OPM's and amp's.The 5.5"?
Ok thanks for the advice.
So, those 6.5" pads are mostly for the rotaries or flex?
Once again, the 6.5" pads are too big and heavy to spin on the PC7424. It will work with the new PC7424XP which has more power.So, if i stick with the 6.5", it will take me longer to do some corrections?
Or will it be a futile attempt to do any corrections?
FWIW, I use the Meguiar's 8207/9207 on my G100 (it's a 7335), the pads are 7" or so. They spin fine for me on speed 5 and obviously 6.....The W68DA backing plate is a must to match the pads. Not sure the difference between the 7424 and 7335 is.
